Sponsored by: Real Truck
Roughcountry leveling kit
Old Nov 1, 2013 | 11:59 AM
Rob's F-250's Avatar
Rob's F-250
I have a 2002 F-250 that I Recently installed a Rough Country leveling kit on and it lifted the front higher than the back. Do I need to put 350 blocks on the back? Will this help.
Tires 35X12.50 Cooper STT on Rock Star 20"x10 and they Rub the Front back finder wall any suggestions.
Old Nov 1, 2013 | 02:28 PM
2ndStroke's Avatar
2ndStroke
Ya, f250s are pretty level stock, need to lift the back a bit to get it back level. A lot of guys do the f350 blocks.
What are they rubbing on? Just the fender liner? Can you zip tie it back a bit?
Old Nov 1, 2013 | 02:40 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
4" blocks, or an add-a-leaf will lift it up. After 13 years the rear springs could be sagged a good bit, so an extra leaf might tighten the load bearing capacity back up a little bit.
If the tires rub on both sides evenly, going up is the only solution that will actually gain you flex and wheel travel. Maybe an AAL up front, plus an AALin the rear with a 4" block.
Old Nov 1, 2013 | 04:59 PM
Rob's F-250
Can I post picks on this conversation thread to better inform you all.
russ2387
Nov 8, 2009 10:25 AM
Dean88
15
Dec 3, 2007 11:02 AM
03PwrStk
Nov 23, 2007 10:35 AM
cdrmotorsports
Jun 11, 2007 07:58 PM
4xfreak
Dec 13, 2005 07:42 PM
