Help getting oasis report!
Sometimes it helps to grease the skids with the potential to use them for work on the truck if there are some outstanding issues.
Line 1 prt # bxt 65850 mtrcraft battery labor op # 10654c17
Line 2 prt # bxt 65750 mtrcraft batery labor op # 10654ca
End of Report
What little I understand about this report appears to overall clean.
Report Run Date: 2013-10-31 18:04:31.793 EDT
Report Summary
- Class: Pickup - Full Sized
- Engine: 6.0L V8 FI
- Country of Assembly: United States
- Vehicle Age: 7 year(s)
- Calculated Owners: 2
- VIN: 1FTSF20P66ED66864
- Year: 2006
- Make: Ford
- Model: F250 Super Duty XL
- Style/Body: Regular Cab 2D
<!--vehicle-summary--><!-- start score box -->This vehicle's AutoCheck Score
<table id="Table_01" border="0" cellSpacing="0" cellPadding="0" width="210" height="97"><tbody><tr><td colSpan="11">
</td></tr><tr><td colSpan="7">
</td><td rowSpan="2">
</td></tr><tr><td>
</td><td>
</td><td>
</td><td>
</td><td>
</td><td>
</td><td>
</td></tr></tbody></table>The AutoCheck Score is a summary of your vehicle's history. It lets you compare similar vehicles with ease.
About the AutoCheck Score
<!-- end score box --><!-- start assured/buyback box -->This vehicle qualifies for Buyback Protection
Safeguard your investment with AutoCheck Buyback Protection. It reduces the risk in buying a used vehicle.<!-- LINK for assured feature --><!-- Marketing wants the BBP seal and text but not the link for reynolds trial users. the assured feature is turned on so when the trial becomes perminate nothing has to be done to the BBP -->About Buyback Protection
<!-- Score-right --><table id="vin-summary" cellSpacing="0"><tbody><tr><td>
</td><td>AccidentCheckReported accidents: 0</td></tr><tr><td>
</td><td>Title and ProblemCheckYour vehicle checks out!</td></tr><tr><td>
</td><td>OdometerCheckYour vehicle checks out! Last Reported Odometer Reading: 44,606
</td></tr><tr><td>
</td><td>Vehicle Use and EventCheckSpecific vehicle use(s) or events reported </td></tr></tbody></table>
<!--Icon-->
<!--Center section-->View Full History
<!--Box--><!--Score-summary--><!--Score-section-->
AccidentCheckNot all accidents / issues are reported to AutoCheck.
Your Vehicle Checks Out! There have been no accidents reported to AutoCheck for this 2006 Ford F250 Super Duty XL (1FTSF20P66ED66864). AutoCheck receives its accident data from government sources and independent agencies, and based on the information available to us, we have found that no accidents have been reported on this vehicle. <table id="AC1FTSF20P66ED66864" class="section"><tbody><tr><td></td></tr></tbody></table><!-- End Section: Accidents -->
Your Vehicle Checks Out! AutoCheck's database for this 2006 Ford F250 Super Duty XL (1FTSF20P66ED66864) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and EventCheck for reported accidents that can affect vehicle safety and value. <table id="titlecheck-list" class="report listing"><tbody><tr><th class="check-header"> 0 Problem(s) Reported:</th><th>15 Title/Problem areas checked:</th></tr><tr><td class="bottom" colSpan="2"><table id="TC1FTSF20P66ED66864" class="section"><tbody><tr><td class="check-header">
</td><td> No abandoned title record </td></tr><tr><td class="check-header">
</td><td> No damaged title or major damage incident record </td></tr><tr><td class="check-header">
</td><td> No fire damaged title record </td></tr><tr><td class="check-header">
</td><td> No grey market title record </td></tr><tr><td class="check-header">
</td><td> No hail damage title record </td></tr><tr><td class="check-header">
</td><td> No insurance loss title or probable total loss record </td></tr><tr><td class="check-header">
</td><td> No junk or scrapped title record </td></tr><tr><td class="check-header">
</td><td> No manufacturer buyback/lemon title record </td></tr><tr><td class="check-header">
</td><td> No odometer problem title record </td></tr><tr><td class="check-header">
</td><td> No rebuilt/rebuildable title record </td></tr><tr><td class="check-header">
</td><td> No salvage title or salvage auction record </td></tr><tr><td class="check-header">
</td><td> No water damaged title record </td></tr><tr><td class="check-header">
</td><td> No NHTSA crash test record </td></tr><tr><td class="check-header">
</td><td> No frame/unibody damage record </td></tr><tr><td class="check-header">
</td><td> No recycling facility record </td></tr></tbody></table></td></tr></tbody></table><!-- End Section: section-title-and-problemcheck -->
OdometerCheck
Your Vehicle Checks Out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 2006 Ford F250 Super Duty XL (1FTSF20P66ED66864) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage. <table id="odometercheck-list" class="report listing"><tbody><tr><th class="check-header">0 Problem(s) Reported:</th><th style="width: 12%;">Mileage</th><th style="width: 20%;">Date Reported</th><th></th></tr><tr><td class="bottom" colSpan="4"><table id="OC1FTSF20P66ED66864" class="report listing"><tbody><tr><td class="check-header">
</td><td style="width: 12%;"> 3 </td><td style="width: 20%;"> 06/04/2007 </td><td style="width: 53%;"></td></tr><tr><td class="check-header">
</td><td style="width: 12%;"> 42 </td><td style="width: 20%;"> 06/27/2007 </td><td style="width: 53%;"></td></tr><tr><td class="check-header">
</td><td style="width: 12%;"> 6,457 </td><td style="width: 20%;"> 12/01/2008 </td><td style="width: 53%;"></td></tr><tr><td class="check-header">
</td><td style="width: 12%;"> 6,456 </td><td style="width: 20%;"> 12/02/2008 </td><td style="width: 53%;"> not included in rollback calculation </td></tr><tr><td class="check-header">
</td><td style="width: 12%;"> 6,480 </td><td style="width: 20%;"> 02/24/2009 </td><td style="width: 53%;"></td></tr><tr><td class="check-header">
</td><td style="width: 12%;"> 44,606 </td><td style="width: 20%;"> 09/23/2013 </td><td style="width: 53%;"></td></tr></tbody></table></td></tr></tbody></table><!-- End Section: section-odometercheck -->
Information Reported! AutoCheck shows additional vehicle uses or events reported to AutoCheck<!-- if noScore feature do not display text about 3rdparty inspection --> for this 2006 Ford F250 Super Duty XL (1FTSF20P66ED66864). This includes reported vehicle uses such as rental or lease, and events such as whether the vehicle has been reported to have had a loan/lien or a duplicate title issued. Other events show if the vehicle has a reported accident and how many calculated accidents or if it has been reported stolen or repossessed. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase. <table id="vehicle-use-list" class="report listing"><tbody><tr><th class="check-header"> 0 Event(s) Reported: </th><th>6 Vehicle uses checked: </th></tr><tr><td class="bottom" colSpan="2"><table id="VI1FTSF20P66ED66864A" class="report listing"><tbody><tr><td class="check-header">
</td><td> No fleet, rental and/or lease use record </td></tr><tr><td class="check-header">
</td><td> No taxi use record </td></tr><tr><td class="check-header">
</td><td> No police use record </td></tr><tr><td class="check-header">
</td><td> No government use record </td></tr><tr><td class="check-header">
</td><td> No livery use record </td></tr><tr><td class="check-header">
</td><td> No driver education record </td></tr></tbody></table></td></tr></tbody></table><table id="vehicle-event-list" class="report listing"><tbody><tr><th class="check-header"> 2 Event(s) Reported: </th><th> 9 Vehicle events checked:</th></tr><tr><td class="bottom" colSpan="2"><table id="VI1FTSF20P66ED66864B" class="report listing"><tbody><tr><td class="check-header">
</td><td> No accident record reported through accident data sources </td></tr><tr><td class="check-header">
</td><td> No corrected title record </td></tr><tr><td class="check-header">
</td><td> No duplicate title record </td></tr><tr><td class="check-header">
</td><td> Emission/safety inspection record(s) </td></tr><tr><td class="check-header">
</td><td> Loan/Lien record(s) </td></tr><tr><td class="check-header">
</td><td> No fire damage incident record </td></tr><tr><td class="check-header">
</td><td> No repossessed record </td></tr><tr><td class="check-header">
</td><td> No theft record </td></tr><tr><td class="check-header">
</td><td> No storm area registration/title record </td></tr></tbody></table></td></tr></tbody></table><!-- End Section: section-vehicle-use-and-eventcheck -->Full History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date 2013-10-31 18:04:31.793 EDT
Vehicle: 2006 Ford F250 Super Duty XL (1FTSF20P66ED66864)
<table id="full-history-list" class="report listing"><tbody><tr><th>Event date</th><th>Location</th><th>Odometer reading</th><th> Data Source</th><th>Details</th></tr><tr><td> 04/22/2006 </td><td> CO </td><td>
</td><td> Independent Source </td><td> VEHICLE MANUFACTURED AND SHIPPED TO DEALER </td></tr><tr><td> 03/31/2007 </td><td> CO </td><td>
</td><td> Motor Vehicle Dept. </td><td> EMISSION INSPECTION </td></tr><tr><td> 06/04/2007 </td><td> LITTLETON, CO </td><td> 3
</td><td> Motor Vehicle Dept. </td><td> TITLE (Title #:10T299294) </td></tr><tr><td> 06/27/2007 </td><td> DUMONT, CO </td><td> 42
</td><td> Motor Vehicle Dept. </td><td> TITLE (Title #:51E147601) (Lien Reported) </td></tr><tr><td> 07/09/2007 </td><td> DUMONT, CO </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 07/28/2008 </td><td> DUMONT, CO </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 12/01/2008 </td><td> MOUNTAIN REGION </td><td> 6,457
</td><td> Auto Auction </td><td> REPORTED AT AUTO AUCTION AS DEALER VEHICLE </td></tr><tr><td> 12/02/2008 </td><td> MOUNTAIN REGION </td><td> 6,456
</td><td> Auto Auction </td><td> REPORTED AT AUTO AUCTION </td></tr><tr><td> 02/11/2009 </td><td> HOUSTON, TX </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 02/24/2009 </td><td> HOUSTON, TX </td><td> 6,480
</td><td> Motor Vehicle Dept. </td><td> TITLE (Title #:10177139853092207) (Lien Reported) </td></tr><tr><td> 02/01/2010 </td><td> HOUSTON, TX </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 02/01/2011 </td><td> HOUSTON, TX </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 02/01/2012 </td><td> HOUSTON, TX </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 02/01/2013 </td><td> HOUSTON, TX </td><td>
</td><td> Motor Vehicle Dept. </td><td> REGISTRATION EVENT/RENEWAL </td></tr><tr><td> 09/23/2013 </td><td> TX </td><td> 44,606
</td><td> Auto Auction </td><td> REPORTED AT AUTO AUCTION </td></tr></tbody></table><!-- End Section: full-history -->
This Vehicle's Glossary
Below are the specific definitions for events that appear in this vehicle's report.
More information is available in the full AutoCheck glossary.
<table id="vehicle-glossary-list" class="report listing"><tbody><tr><th>Term</th><th>Section Location</th><th>Definition</th></tr><tr><td> Emission/Safety Inspection </td><td> Vehicle Use and EventCheck </td><td> An approved emission testing station has inspected the vehicle to measure the amount of pollutants the vehicle emits into the environment. </td></tr><tr class="alt"><td> Loan/Lien </td><td> Vehicle Use and EventCheck </td><td> A loan/lien is the legal right to take and hold or sell the vehicle of a debtor as security or payment for a debt. Normally, a vehicle will have a lien due to a loan or unpaid repair bill against the vehicle. Check with the seller to ensure that the lien has been satisfied. </td></tr></tbody></table><!-- End Section: section-vehicle-glossary -->
Sarge
