headlight switch question.
Old Oct 31, 2013 | 01:42 PM
86ford302help's Avatar
86ford302help
I have a 67 f100, and the brake lights wont go off, if I unplug the headlight switch then they go off. They didn't always do this and I have not messed with the wiring, does this mean the problem is in the switch?
Old Oct 31, 2013 | 01:43 PM
86ford302help
I thought that the running lights should come one when I pull the switch out to the first notch, which is true for the front. should it be the same in the rear? the switch works everything else fine.
Old Oct 31, 2013 | 01:54 PM
86ford302help
well, lol. the redneck fix all has stayed true to itself. I took the headlight switch and banged it on the garage floor a few times and now my tail lights go off. But I do not get brake lights, would the brake lights be on the same fuse as the dome light?
Old Nov 1, 2013 | 12:03 AM
orich's Avatar
orich
That little fuse box say what fuse goes into it. It has raised lettering but you need to get up close with some cheaters on to see the small print. Test for power at the brake light switch.
That a hot wire loop. 1 side is hot other zip. Put a test light or a jumper in the socket then see if Blights are on...orich
texas_tech_guy83
Electrical Systems/Wiring
13
Aug 14, 2021 12:27 PM
rutrows
Oct 21, 2010 03:03 AM
otahite
Feb 28, 2009 08:46 PM
tmwindham
Jun 17, 2005 10:52 PM
MontanaFord
Mar 14, 2004 02:15 AM
