5.4 headers?
Old Nov 4, 2013 | 12:19 PM
  #31
LivingLarge's Avatar
LivingLarge
Originally Posted by Toreador_Diesel
Then you need 4.10 gears, it'll give you the truckly less sluggish feel. Either that or 4.30 gears...
Nope, he's saving for a 6.0.... Won't need it don't tell his wife
Old Nov 4, 2013 | 01:12 PM
  #32
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by LivingLarge
Apocalypse, pm me your name and address... I will help you get this started.
See? Now he's got you in his clutches....
I started thinking about getting a 6.0, not too serious about it at all because I had my 7.3 and loved it.
Then after some PM's, phone calls, and some encouragement to not to be such a wuss I started looking, again, not too serious about it...but slightly intrigued.
Some PM's and 2 thread later, I drove home a new to me 2005 Excursion and didn't even realize what had happened
From there I knew what Living Large was talking about becuase I have this huge grin on my face I have yet to wipe off
Join us Apocalypse it's bliiiiiiiiisssssssss.....
Old Nov 4, 2013 | 02:05 PM
  #33
F350BOSS's Avatar
F350BOSS
Originally Posted by Apocalypse
Nope, no towing (on a regular basis) but I just want it to be a little less sluggish and a little more "truckly" without just gutting the cat and running 5 inch pipes and a rebel flag (the South lost, get over it) on a pole off the rear bumper.
Lol im running 3 in si-do and my tourqe is better than ever!!! I might post a video on youtube...
Old Nov 15, 2013 | 02:53 PM
  #34
Apocalypse's Avatar
Apocalypse
Ok, here is my door sticker...
Is it time to swap gears?
Old Nov 15, 2013 | 03:12 PM
  #35
Bigpipes 35's Avatar
Bigpipes 35
You have a 3:73 open diff, Time for some 4:30 I would say. If you are going with anything larger than stock tires go 4:56..
Old Nov 15, 2013 | 03:29 PM
  #36
Apocalypse's Avatar
Apocalypse
I have some OEM 18's now and will more than likely go with some larger tires but nothing huge. So is there a rear end swap I should look for or just swap the gears themselves? Any recommendations on doing it or should I just pay to have it done? Is open LSD or no? Should I/can I afford to get an LSD for it?
Old Nov 15, 2013 | 09:26 PM
  #37
Bigpipes 35
Then I would go with the 4:56 , as far as doing it yourself if you haven't done one before than I wouldn't recommend it because it takes a knack. I don't think you will find a rear with that setup so I would just buy the gears somewhere or go with a place like 4wheel parts and they will give you a package deal.
As for the LS you could get a price from them on adding one if you think you need it. If its a pavement princess I would probably leave the diff open..
Old Nov 16, 2013 | 01:35 AM
  #38
Bently_Coop's Avatar
Bently_Coop
Gears and a detroit true trac or lsd would be sweet all at once. If i were spending the money with open diff and plan on keeping the excursion I would do both.
Old Nov 16, 2013 | 02:08 AM
  #39
Skip1970's Avatar
Skip1970
its not that hard, go for it, heck you seen some of the grease monkeys in shops and they can do it
Old Nov 19, 2013 | 02:41 AM
  #40
F350BOSS's Avatar
F350BOSS
Now that i found a way to turbo charged the 5.4l, will the stock injector work or should i get the 24lb or 42lb injector? The turbo is a t3/t4 70mm and im thinking of getting spearco intercooler.
Old Nov 19, 2013 | 02:55 AM
  #41
Bently_Coop
It depends on what the percentage of injectors you will be using. Larger will be better as when youu are using forced induction it will require more air and fuel. Also need to look into how to tune the pcm.
I reccomend starting a new thread so more people will chime in and not get this off topic.
Raider50
Modular V8 (4.6L, 5.4L)
18
Nov 15, 2021 03:51 PM
06pbmkc
Oct 21, 2018 08:19 PM
kenny nunez
Ford Truck Parts for Sale
Jun 28, 2016 01:41 PM
maddogken
Mar 18, 2010 05:07 AM
FTE Ken
2004 - 2008 F150
Dec 7, 2008 12:55 PM
