Tachometer issue resolved
Old Oct 30, 2013 | 07:46 AM
boonslick's Avatar
boonslick
Hello guys!
Some of you may recall my previous thread with an "erratic" tachometer.
I took the advice of one of our ford friends and went to the boneyard and found a tach for $10, installed it and all is back to normal.
Interestingly, the tachometer came off a 1989 that was made in Canada?
Thanks to all
Mark
Old Oct 30, 2013 | 11:29 AM
dixie460's Avatar
dixie460
Good, glad to hear it.
These trucks are getting up there in age, and some of the electronic components are showing it. Solder connections crack after many years of hot/cold/vibration, capacitors leak as they break down, etc.
If you still have your old tach, might be worth taking it apart and inspecting the board. If you can solder, you can probably get the components you need for a couple bucks.
Old Oct 30, 2013 | 11:38 AM
boonslick's Avatar
boonslick
These trucks are getting up in age, and some of the electronic components are showing it. Solder connections crack after many years of hot/cold/vibration, capacitors leak as they break down, etc.
Yes I kept the original tachometer and perhaps there is a broken or loose terminal.
Thanks for the tip!
Mark
Sycostang67
41
Dec 22, 2018 06:27 PM
LARIAT 85
Apr 17, 2009 09:33 PM
Sycostang67
'80-'86 HOWTO's
Sep 23, 2008 12:43 PM
fordmarshall111
2004 - 2008 F150
Apr 12, 2005 11:55 PM
DanMan7
Jul 19, 2004 02:32 PM
