HOWTO - Tachometer Repair
Old Aug 3, 2008 | 09:47 PM
Sycostang67's Avatar
Sycostang67
I've been fighting an intermittent problem with my tach for awhile now. It started last year. It just stops working sometimes. Sometimes it wont work at all for a week or 2 and when it does work it rarely lasts all day. It will usually jump at random while driving. I have replaced the tach and the circuit paper, cleaned all the contacts on the dash and plug, and jiggled every wire I could find but nothing seems to trigger it. I dont know what else to do.
Old Aug 3, 2008 | 11:24 PM
Piffery1's Avatar
Piffery1
You've probably already done it, but look where the tach wire fastens to the coil terminal.
Old Aug 4, 2008 | 12:16 AM
hoxiii's Avatar
hoxiii
Check the one wire tach connector under the hood by the DSII box. Mine was cracked and corroded a little on the inside causing goofy tach signalling occaisonally.
Justin
Old Aug 4, 2008 | 06:03 PM
Eddiec1564's Avatar
Eddiec1564
Sounds like the problem I had on my tach. What I found was inside on the circut pc board of the Tach was some old yellow colored glue that turned brown and started conducting current. I cleaned off the browning yellow glue and resoldered some cold joints and that took care of that problem. Since then I fixed about 5 tachs for the same thing. Funny thing is Mitsubishi TV's of the late 80's/ early 90's had the same yellow glue that browns up and causes all types of problems...
Old Aug 5, 2008 | 11:19 AM
Sycostang67
What did you use to clean the glue? I can take apart my extra tach and see since both are doing the same thing.
Old Aug 5, 2008 | 03:17 PM
Eddiec1564's Avatar
Eddiec1564
Once that yellow glue turns brown, that stuff will easly scrape off. Just scrape off the glue from the componet's legs, to keep from conducting current across. If there is some glue not turning brown, it will be harder to pick it out. Get some pc board cleaner to rinse off the pc board, let it dry and that should be it. My tach has not acted up in 8 or so years now. That yellow glue was some ones idea to keep things from virbrating and causing bad connections. But after years in heat they never though it would turn condutive.(although I wonder about that....). I did the same thing you did. Replaced tach, wires and ect... then hooked up a aftermarket tach to the back connectors in the cluster. That showed the problem was inside the tach unit and the aftermarket never acted up but the orginal did.
Old Aug 5, 2008 | 06:32 PM
Sycostang67
Eddie you ROCK!! I went out and took apart my spare tach and it was full of yellow glue. I spent about 20 minutes scraping it off and hosed it with cleaner. I checked the tach in the truck before I swapped them and still it wasn't working. I swapped in the one I had just cleaned and it worked. I then took the other tach and opened it up. The glue was brown in this one and a lot easier to clean, only took about 5 minutes and there wasn't as much either. I threw it back in and it started working too. Finally, I hate having dead gauges in my dash.
Old Aug 5, 2008 | 06:40 PM
uncle.stosh's Avatar
uncle.stosh
Good to know. Thanks for the info.
Old Aug 6, 2008 | 04:34 PM
Eddiec1564's Avatar
Eddiec1564
Good to hear you got them fixed. So far I only found that type of problem with the 80 to 86 tachs. Not sure about the 87 and up tachs.
Old Aug 7, 2008 | 10:10 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
i just posted a thread in 87-96 forum with my diesel. Mine is a 91 but i'm going to go check that. cant start it right now, i'm waiting on an injector line to come.. threads wrecked, and the injector threads wrecked. all this to fix fuel seap.
Old Sep 21, 2008 | 08:39 PM
LARIAT 85's Avatar
LARIAT 85
OK, the tach wire on my truck is fastened to the coil terminal just fine. However, I traced the wire back to where it connects to the truck and the wire is chewed off and just sticking straight up close to the firewall but is connectined to nothing! Where does the wire go from here?
The thing is, my tach IS working; the problem is the tach reads too high once it goes into overdrive. (302 carbureted V8 w/ AOD) How do I fix this problem??
Old Sep 22, 2008 | 02:40 PM
Eddiec1564's Avatar
Eddiec1564
Sounds like some mouse had fun. Does the tach show idle speeds or change when you rev the engine? What color is the wire that was chewed up? Not fun when a rodent eats up things. Just got rid of them from my truck. This time they ate up the brake booster vacuum line..... going to recrute a rat snake or black snake again..
Old Sep 22, 2008 | 04:30 PM
LARIAT 85's Avatar
LARIAT 85
Yes, the tach works perfectly fine otherwise. Seems to be reading too high when it goes into overdrive. It doesn't make sense to me. Aside from reading too high, the tach seems to work normal, yet there is a chewed up wire in the engine compartment. The wire is yellow and actually says "Tachometer" on it. Any ideas?
Old Sep 23, 2008 | 10:08 AM
Sycostang67
Are you sure the tach is off, maybe your OD band is worn and your tranny is slipping. Just a thought. If the wire has tachometer printed on it, it's most likely not a factory wire. A PO probably had an aftermarket tach in there at some time.
Old Sep 23, 2008 | 12:43 PM
LARIAT 85's Avatar
LARIAT 85
AOD transmission was just rebuilt, so there are no problems on that end.
The truck was my father's, he bought it new, and it came with a factory tach, the one that is still in there.
I changed from EEC-IV/TFI to Duraspark II ignition, using stock Ford parts and a Duraspark wiring harness from Painless. When it was first hooked up, everything, including the tach, worked fine. Now, the wire is off and the tach is reading screwy and I don't know where the wire went to.
