99 ranger gas/temp guage problem
Old Oct 29, 2013 | 11:59 PM
bbfmavrick's Avatar
bbfmavrick
Just purchased this truck and noticed the gas and temp guages neither work. Where do I start/ How about fuse box?
Old Oct 30, 2013 | 12:43 PM
KF4EYR's Avatar
KF4EYR
check fuses and the relays that is under the hood on drivers side fender,,,,
Old Oct 30, 2013 | 01:19 PM
Rockledge's Avatar
Rockledge
Download a copy of a 1999 Ranger Owner's Manual from HERE and it will show you the fuse locations and descriptions.
Old Oct 30, 2013 | 08:54 PM
bbfmavrick's Avatar
bbfmavrick
Thx guy's,I will give it a go.
Old Oct 31, 2013 | 05:18 PM
bbfmavrick's Avatar
bbfmavrick
Checked today,no fuses for gas and temp.
Old Oct 31, 2013 | 05:56 PM
Rockledge's Avatar
Rockledge
You need to check fuse #11 located inside the cab (interior) fuse box.
If the fuse is good, then you need to do some more troubleshooting. Locate the temp. sending unit harness connector. Jiggle it, disconnect it, ground the wire, etc. while checking to see if there is any gauge activity.
mypigpen
May 2, 2010 09:39 PM
mnk1220
1997 - 2003 F150
Feb 18, 2004 06:13 AM
