Gas and Temp Guage Problems
Old May 2, 2010 | 06:10 PM
mypigpen's Avatar
mypigpen
Both the gas and temp guages on my 1988 F-150, I6, Manual Trans are not working. From previous posts it must be a ground problem. Is the gas tank grounded to the frame or does a ground wire run through the harness? Any suggestions on where I should start looking for the problem?
Old May 2, 2010 | 09:39 PM
quickie70's Avatar
quickie70
I had the same issue in my 89 f350, it ended up being the connector behind the gauge cluster. The electrical connection was slightly unplugged. Plugged it back in and it started working perfectly.
