Adding Hydro-Boost
Old Oct 29, 2013 | 10:28 PM
Tofan's Avatar
Tofan
Adding Hydro-Boost
Ok, so some of you might know that I was clearly wrong on thinking that my F350 had hydroboost braking. It does not. Since diesels don't make vacuum and my truck already uses an electric vacuum pump, why not make the switch over to hydroboost? I looked and the Master Cylinder and all the lines, gaskets, brackets would be right at like $300. My question is that for anybody who has installed them before, is there anything else I need to do? I am not going to purchase this yet, just doing research for in the future. I appreciate all replies and information. Thanks fellas.
Old Oct 29, 2013 | 11:41 PM
Chad149's Avatar
Chad149
I don't think it will be worth the effort personally. The vacuum pumps on our trucks are engine driven, very robust units.
Far as doing the swap I would look into brake pressure switches as well, if they made a small change there it would cause havoc with the abs/esp.
Old Oct 30, 2013 | 08:00 AM
TRENT310's Avatar
TRENT310
Couldn't one just buy all the brake system hardware for a 2011 and be done with it? I believe the way the ABS works, since it's on the brake fluid hydraulic side of the power assist system, is still the same.
The vac boosted power brake systems do have a different pedal feel. It's somewhat similar to how it feels when you're driving a gasser truck, there's less resistance to your foot pedal application.
Old Oct 30, 2013 | 01:07 PM
Slowlearner's Avatar
Slowlearner
As already posted, they use a mechanical vacuum pump for the brake booster, not electric.
I beg the question: "Why bother with the hassle?"
My 2005 had hydro boost, my 2012 has vac boost... personally I have not seen any difference in braking performance.
Old Oct 30, 2013 | 01:13 PM
2ndStroke's Avatar
2ndStroke
I don't see why you would, you didn't even know you didn't have them not long ago, your brakes cant be that bad then??
Old Oct 30, 2013 | 01:25 PM
69cj's Avatar
69cj
In my op. the vacum system is also easier to work on when you do have a problem. Less expensive also.
Old Oct 30, 2013 | 01:49 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I'd concur with all of the above. Not too hard to switch, but at the end of the day doesn't really add anything. In fact, makes your steering worse.
Old Oct 30, 2013 | 01:51 PM
kper05's Avatar
kper05
Isn't the hydroboost system more expensive to repair?
I certainly would take a hydroboost system if it was given to me because it was nice with the 6.4L but the braking power of my F250 has room to spare so I don't see a need and Ford didn't either.
I know I can skid to a stop on pavement with 3,000 lbs empty trailer pushing me down a hill after "trailer disconnected" reported on the dash all of a sudden.
Do you feel you don't have as much braking force as your previous hydroboost truck?
Old Oct 30, 2013 | 07:32 PM
senix's Avatar
senix
Hydro is great for the heavy towing applications. My 250 had it and of course my drw has it as well.
Lots of heaving towing so then it is worth it, otherwise no need.
Old Oct 30, 2013 | 08:13 PM
Tofan's Avatar
Tofan
Haha perfect! Sorry my post was confusing, I am not complaining about my brakes, I am more then happy with mine. You guys have said enough, I won't be switching, I didn't know how big of a difference it made, but obviously it's not that big of a difference. Also sorry about stating thats it's electric and not mechanical, that was my mistake. Good enough for me then, was just trying to gather some information, as I won't be using my truck to mainly tow, then I will just go ahead with the advice you guys gave me. Thanks!
pdqford
2015 + Expedition & Navigator
Nov 8, 2018 08:04 PM
boggerted
18
May 17, 2018 01:54 PM
nonrev321
Apr 28, 2016 04:45 AM
93f250tn
Feb 4, 2015 09:57 PM
goneinsixty
Feb 20, 2005 10:53 PM
