Compression Test
Old Oct 31, 2013 | 10:05 AM
  #31
oldbird1965's Avatar
oldbird1965
Originally Posted by tshrager
No problem Glenn. Disregard my text!
OK........
Old Oct 31, 2013 | 12:36 PM
  #32
cowmilker08's Avatar
cowmilker08
Its definately worth the wait Glenn. I couldn't find one around here and there is a Parker brass fitting plant 1/2 mile from my house. I decided I'd just build an adapter myself. It worked pretty well, but was not worth the effort or time spent. Just be patient and get the right stuff.
Henry Ford said something like, "If you find you need a machine and don't buy it, then in the end you'll find you've paid for it and don't have it."
Old Oct 31, 2013 | 07:53 PM
  #33
oldbird1965
haha, how true that quote is! A business in town ordered it for me, should have it Monday.
Old Nov 3, 2013 | 09:29 AM
  #34
oldbird1965
When I get this fitting to be able to do a compression check, will it matter if I hook up the batteries and just use the starter relay to turn the motor over? I have the dash out for the sound proofing that I've been doing so the key will not work, LOL. I just don't want to connect the batteries and screw something up because every thing is unplugged from the dash. I don't need any more headaches, LOL
Old Nov 3, 2013 | 11:12 AM
  #35
ReBilld's Avatar
ReBilld
That should be fine Glenn. Just make sure you remove fuse #22.
Old Nov 3, 2013 | 11:33 AM
  #36
oldbird1965
OK, thanks!
Old Nov 4, 2013 | 08:06 PM
  #37
oldbird1965
OK, here is the deal. I'm about ready to throw this compression tester in the garbage and buy a good one. If you look at the pictures in this thread in the first post, this is exactly what I now have. Homemade Compression Adapter... - Diesel Bombers
I tried on #1, #3, & #5 and the needle with jump to 250 to 300 very fast and just as fast go back to zero. In the pictures there isn't a check valve to hold the pressure, on mine there isn't either. I would think there would be one some where. Is there suppose to be one by the pressure release button by the gauge?
I'm going to do a compression check even if I have to buy an expensive setup. grrrrrrrrrr
Old Nov 4, 2013 | 08:23 PM
  #38
tshrager's Avatar
tshrager
I hate that you're having all these problems with it Glenn. I've got some dough coming in this week, so guys should be getting parts soon. Just let me send you mine!
Old Nov 4, 2013 | 08:31 PM
  #39
427 fordman's Avatar
427 fordman
There should be something Glenn. The one I have for gas motors has a tire valve stem dealy thingy in the end of the hose/fitting that goes in the spark plug hole.
Old Nov 4, 2013 | 08:32 PM
  #40
oldbird1965
I just texted you, LOL. I'll text you back my address. I just want to understand why mine is working. Like I said, maybe there should be a check valve in the quick disconnect piece and mine doesn't. If it isn't that, I don't have any idea.
Old Nov 4, 2013 | 08:36 PM
  #41
oldbird1965
That's what I'm thinking Darin, the other pieces in the kit have check valves.
Old Nov 4, 2013 | 08:52 PM
  #42
ReBilld's Avatar
ReBilld
I have the same kit you do Glenn, and the fitting in the kit that has 1/8" pipe thread is the one I used to make my adapter, and it had a schrader valve in it.
Old Nov 4, 2013 | 08:59 PM
  #43
tshrager's Avatar
tshrager
Like just texted you Glenn, but I have the same thing that these guys are saying. Schraeder valves in the different stem pieces, if that makes sense.
Old Nov 4, 2013 | 09:10 PM
  #44
oldbird1965
Mine doesn't have a schrader valve in it
Edit: I wonder if I can use one of the other pieces and adapt it in there? I might try.
Old Nov 4, 2013 | 09:22 PM
  #45
ReBilld's Avatar
ReBilld
Is the valve just missing from that one piece? If so, just screw one out of one of the other pieces and put in that one.
