6.2L V8 Discuss the 6.2L V8
TIME OUT!
Old Oct 29, 2013 | 06:07 PM
T diesel's Avatar
T diesel
TIME OUT!
On my 06, if I opened my passenger door to listen to the radio, the lights would shut off on their own after a time.
On my 13 they stay on forever.
Anyone know of a setting?
Thanks.
Old Oct 29, 2013 | 06:35 PM
Powelligator's Avatar
Powelligator
Here's an excerpt from the 2013 Owner's Manual:
The autolamp system also keeps the lights on for a predetermined amount of time after the ignition switch is turned to off. You can change the amount of time the lamps stay on by using the programming procedure that follows:
Autolamps - Programmable Exit Delay
Programmable exit delay allows the length of the autolamp exit delay to be changed.
To program the auto lamp exit time delay:
1. Start with the ignition in the off position and the headlamp control in the autolamp position.
2. Turn the headlamp control to off. 3. Turn the ignition switch to on and then back to off.
4. Turn the headlamp control to the autolamp position. The headlamps will turn on.
5. Wait the desired amount of time for the exit delay you want (up to three minutes), then turn the headlamps off.
Good luck!
Joe
jtcsrvbi
2004 - 2008 F150
Jul 23, 2015 12:41 AM
Meter maid Rita
May 29, 2010 02:09 PM
Sabbot
2004 - 2008 F150
Mar 7, 2009 06:05 PM
riggz
Feb 18, 2009 09:04 PM
sritzau
Electrical Systems/Wiring
Aug 3, 2003 06:03 PM
