Bad vibration when given partial throttle
Old Jan 13, 2014 | 08:02 PM
  #46
adam83's Avatar
adam83
@Jim and Gary: yes they came with both clips, and thanks for the part # lookup. My driveshaft uses the same U joint, front and back. Part #434 in the MOOG/PRECISION Brand. Each joint has 2 caps with 1.062" diameter, and 2 caps with 1.125" diameter. The groove in them must be for a different setup that uses the same joints, I was a little worried about losing surface area contact, but after I pressed them in it felt just fine.
@Dave: I tightened as far as I could get it, which was about 160ft lbs. If it walks off again I will get a new nut and locktight it. I have the u-bolt style retainers for my u joints, and I prob tightened them more than they should've been, but after test drive I didnt hear/feel anything strange.
Went for test drive and NO MORE VIBRATION. With the new timing chain, no emmisions equipment, no vacuum leaks and this vibration fixed, the truck drives better than ever. Runs great.
All thats left on my list is my front passenger rotor. It's in bad shape. Do I need that special 4 pronged socket to get the rotor off?
Old Jan 13, 2014 | 08:25 PM
  #47
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You can usually" borrow" those sockets from the chain stores.
I'm assuming you have a D44HD?
Old Jan 13, 2014 | 08:34 PM
  #48
adam83's Avatar
adam83
I dont know, I've been looking all over with a wire brush for a 44 or 50 mark and cant find one. Ill have to read up again on how to tell the difference.
Old Jan 13, 2014 | 08:43 PM
  #49
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Does the hub come straight out to the lockout?
Or does it taper to a smaller lockout?
Old Jan 13, 2014 | 09:39 PM
  #50
Gary Lewis's Avatar
Gary Lewis
Glad you got that problem fixed. It is amazing how well these old trucks can drive when you get them sorted.
Old Jan 13, 2014 | 10:01 PM
  #51
adam83's Avatar
adam83
Not quite sure.. hard to see right now
Old Jan 13, 2014 | 10:07 PM
  #52
adam83's Avatar
adam83
I think its a 44
96broncoXlt
1978 - 1996 Big Bronco
Apr 8, 2015 11:21 PM
Big
Jun 26, 2009 08:34 AM
anaphe
Apr 23, 2009 04:24 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Apr 1, 2008 06:43 AM
dlund
Aug 2, 2002 03:23 PM
