Vibration driving me crazy
Old Apr 23, 2009 | 12:03 PM
anaphe's Avatar
anaphe
OK So I am getting ready to tow my race car and trailer about 600 miles through the rockies to an event in 3 weeks and I really want to see if I can track down and anhilate the vibration I am getting. Has been there since I bought the truck and now I am ready to tackle.
I am going to replace the 2 joints on the rear shaft as a preventative measure (cause they are cheap) but something tells me this isn't the issue. I have read everyone elses posts and this is what I plan.
1. remove shaft and replace joints
2. rebalance driveshaft
see where that gets me I am hoping it will make the issue better.
There is little noise other then some "drumming" if I have a bottle of water in the console it shakes like crazy around 65-72 mph if I put it into neutral it still shakes but maybe a bit less.
I have already re-balanced the tires.
Am I on the right track?
Thanks
A
Old Apr 23, 2009 | 12:43 PM
EXv10's Avatar
EXv10
Thanks
A
Check for miss but you say it goes away when put in neutral?????
Old Apr 23, 2009 | 12:46 PM
soutthpaw's Avatar
soutthpaw
yeah a specific speed vibration sounds like an out of balance drive shaft or bad u joint. Definitely a good place to start. did you try rotating the tires too? balancing was gonna be my first recommendation but looks like u did that... Consider a Match balancing if driveshaft and u joints don't fix it... are u sure the hubs and front drive shaft are staying unlocked ?
Does the truck have a suspension lift on it??
Old Apr 23, 2009 | 12:47 PM
anaphe's Avatar
anaphe
No it is still there in neutral it might go from a 9/10 to a 7/10.
and it disappears once the truck drops below 60mph
A
Old Apr 23, 2009 | 12:48 PM
anaphe's Avatar
anaphe
Thanks for the advice. I will check the hubs this weekend.
The truck is a bone stock 4x4 no lift.
Thanks
Old Apr 23, 2009 | 02:49 PM
dave91gt's Avatar
dave91gt
See my post and see if my symptoms match yours. It is titled something to the effect of "out of ideas regarding vibrations". Lots of good information there.
Old Apr 23, 2009 | 03:01 PM
clinter36's Avatar
clinter36
I had a similar vibration - noticeable drone/vibration 65 and up. Replaced the U-joints and no change. It turned out to be the rear drive shaft which a local shop rebalanced. But to be sure I removed the rear drive shaft and drove the truck on the highway in 4x4, I could tell right away the noise/vibration was gone. I suppose it could still have been a pinion bearing, but it was enough to convince me that it was worth taking the DS to the shop and have it balanced.
Old Apr 23, 2009 | 04:24 PM
EXv10's Avatar
EXv10
See Dave's post above
dines78
Dec 10, 2012 07:35 AM
MikefromMT
Aug 15, 2012 03:23 PM
wreckinball
Apr 26, 2010 06:26 PM
FireTail-AR
Feb 10, 2010 08:33 AM
wolfmanagh
Aug 31, 2006 09:16 PM
