Sponsored by: Real Truck
If a U-joint is bad...
Old Jun 24, 2009 | 09:22 PM
Big's Avatar
Big
...will the vibration come and go at different speeds?
I noticed the vibration starting about a week ago. I noticed it under load (accelerating-truck empty. Haven't hauled in a while) between 25-40. Then it smooths out. Then it comes back between 55-65.
At first it was subtle, but now it shakes the driver mirror. It also has gotten to where it is almost constant from 25-65. It occurs only while accelerating. When I let off the pedal, it stops vibrating immediately. Hit the gas, vibration starts again. I have put u-joints in already but that could have been 60-80 miles ago. I currently have 167k on the truck. I'd have to check to be sure tho.
I am fairly confident it is the U-joint but wanted to see what you all think. Last time I replaced them it acted the same, but only at 50-65, not at lower speeds. I suppose it could be the carrier bearing (CC LB) but I checked that for play and it didn't seem more than normal.
Your (collective) supreme wisdom?
Big
Old Jun 24, 2009 | 09:40 PM
DAVE67FD's Avatar
DAVE67FD
Did you reinstall the shaft in the same orientation as when you removed it? It may need to be rebalanced. Try removing the shaft at the pinion end and rotate it 90 deg.. If not reindex on the spline end and try that.
Old Jun 24, 2009 | 10:55 PM
smotrs's Avatar
smotrs
I know it's basic, but easy enough to check and/or overlook. But are all the weights on the wheels? Before disconnecting the drive shaft, I would check for any clean spot on the wheels where weights may have been a week ago or so.
It's a good possibility that it's related to your u-joint replacement since it sounds fairly recent. But you never know.
Old Jun 25, 2009 | 04:33 AM
Big's Avatar
Big
To be clear, last time the Ujoint was replaced was over 80,000 ago and a reputable shop did it. The drive shaft hasn't been off since then. I would think that if the shaft were out of balance, it would shake all the time, and certainly would not stop immediately when I let up on the pedal. I could be wrong tho.
As far as the wheels, all the weights are on still. I checked the drive shaft too, cuz I thought there were weights on it. There are and they still are on.
Old Jun 25, 2009 | 06:46 AM
m350's Avatar
m350
80,000 miles on it since the change,,,,You definetly could have another bad u-joint!
check wheel bearings also!,,,a Buddy of mine told me,,,a well known shop in my area,,,,private guy,,,works on all diesel pickup's,,,says that the main rear diff carrier bearings go bad,,causing a vibration in the truck ! Not sure how true this is,,just what I heard 2nd hand !! ,,,,,I would say after enough miles on the truck it would be good to change them too.
Old Jun 25, 2009 | 08:47 AM
smotrs's Avatar
smotrs
Sorry, thought you said 60-80 miles ago. It may be time to change them again. Looks like m350 has some additional suggestions that I would look at as well.
Old Jun 26, 2009 | 08:34 AM
Big's Avatar
Big
Got the truck back from Fort Wayne Clutch and Driveline. Great guys and reasonable too.
All 3 U-joints had slop or were dry. Drive shaft carrier bearing was going too. The rubber boot around the carrier bearing was cracking as well.
SO...they replaced all 3 u-joints, carrier bearing and balanced the shaft. Total for the job (included remove and reinstall - I didn't drop the shaft myself) $316.xx. Very fair in my opinion.
Now my truck rides like butter. No more mirror shake, no more shudder, just smooth.
As far as the greaseable u-joints, they recommended against them on the F Three Fiddy. They say the solid -joints are much more durable than the greaseable ones. Given that my truck has become a really big station wagon as of late (i.e. not much towing), I am sure the solid u-joints will provide years of enjoyable smooth driving.
Oh, and I see that in my OP I did put 60-80 miles where I should have put 60-80K miles.
Big
nomorecummins
6.4L Power Stroke Diesel
17
Mar 29, 2013 08:49 PM
expo54bx
Oct 2, 2010 12:52 PM
IndyDog
Nov 6, 2007 10:59 AM
Ranger Steve
1983 - 2012 Ranger & B-Series
Sep 6, 2006 06:53 PM
nminer1
Apr 5, 2005 07:25 PM
