flasher relay
Old Oct 27, 2013 | 10:52 PM
HillBillyBuddha's Avatar
HillBillyBuddha
flasher relay
I'm guessing I'll have to go through the wiring harness but my blinkers just stopped working. I thought it might be the relay so I replaced it but that didn't work. So I'm guessing a bad connection or a bad ground.
Just wondering if there is something that's known that goes bad or if I just need to go through it the old fashion way with a multimeter?
Thanks,
Hillbillybuddha
Old Oct 28, 2013 | 04:49 AM
jowilker's Avatar
jowilker
Is both front & back stopped? You are talking about turn signal or 4way?
John
Old Oct 28, 2013 | 08:55 AM
rogue40's Avatar
rogue40
John
...and do your brake lights still work?
Old Oct 28, 2013 | 10:19 AM
HillBillyBuddha
Yeah. Well, now that you mention it, I'm not sure. The rear running lights DO work but I'll go check the brake lights here in a few hours.
The green indicator light inside the cab does NOTwork, the little "click click click" sound does NOT work. Nether the front nor back signals work.
The indicator lever does work. Meaning, it clicks into both positions easily and resets when I turn the steering wheel.
I'll get back at you about the brake lights and the 4 way lights.
Everything worked fine a few days ago and the only electrical thing I've done recently was change the license plate light about a week ago. *
Old Oct 28, 2013 | 01:21 PM
daveengelson's Avatar
daveengelson
Wonder if possibly the fuse, not sure if fuse box are same, blinkers and radio may be on same fuse??
Old Oct 28, 2013 | 01:48 PM
Shadowrider123's Avatar
Shadowrider123
Ive had to chase a few ground gremlins on my 66.
There are several ways to proceed, here is my suggestion:
Raise the hood, turn the ignition on and activate the right or left turn signal.
Use a test light on the turn signal plug, ground the light to the core support and see if you have power.
If you do, its a ground problem, if you do not have power, it could be anything.
That's quick and easy and it will give you a place to start.
Old Oct 28, 2013 | 05:49 PM
rogue40's Avatar
rogue40
Always the best place to start. Check for power on both sides of the fuse.
After that it is starting to look like the blinker switch.
Old Oct 28, 2013 | 06:19 PM
HillBillyBuddha
Jowilker: Brake lights do NOT work. 4 ways (hazards) DO work. (How did you know that the brake lights weren't going to work?)
Daveengles & rogue40: all the fuses checked seem fine. I used the continuity setting on my multimeter and got a "beep" through each fuse.
Old Oct 28, 2013 | 07:07 PM
rogue40's Avatar
rogue40
I'm not Jowilker. He knows more than me.
The brake and blinker circuits are interconnected through the blinker switch. This allows the the side that is blinking to shut off that side's brake light.
The four ways are on a different circuit from the blinkers and brake lights but run down the same wires to the lights. The fact that the four ways operate tells me that the downstream wiring is ok.
The brake lights will still work if the blinker actuator dies so that leaves the one common denominator of the turn signals and brake lights as the turn signal switch.
I would pull the steering wheel and, using a lighted circuit tester and wiring diagram, chase it out from the turn signal switch terminals.
Old Oct 28, 2013 | 07:32 PM
HillBillyBuddha
Ok. Cool. Thanks for helping me generalize the area. I'm not looking forward to pulling the steering wheel (but only because I've never pulled one before.) But it gives me a project for tomorrow.
Old Oct 29, 2013 | 06:40 AM
jowilker's Avatar
jowilker
I'd go back to the flasher before pulling the steering wheel. Not saying the issues is not up there, but if you pull the flasher and see if the 4way will plug in, you might save some baad uttered words.
John
Old Oct 31, 2013 | 12:49 AM
Cazman1955's Avatar
Cazman1955
On my 62, the turn signals also go thru the horn relay. If your horn relay is disconnected or bad, my turn signals will not work on my 62. You may look at that?
jejenkins417
Mar 14, 2011 01:57 PM
borcht warrior
Aug 19, 2010 02:43 PM
alconk
27
Aug 5, 2008 10:10 PM
TexasGuy001
1997 - 2003 F150
Sep 20, 2005 09:05 AM
