Engine ID
Old Jun 20, 2003 | 10:37 PM
dab38's Avatar
dab38
Engine ID
Local mechanic told me the motor in my 68f100 is not stock. Says it's a car engine. Oil pan has "hump" on front of the pan. Oil drains onto the crossmember. He says truck motors have "hump" in the back--doesn't drain on crossmember. I haven't ck'd ser # yet(or stroke)-- block is covered in sludge. Spark plugs are angled-front 2 toward rear-back 2 toward front. I bought starter & fuel pump for 360& they worked. Is he right?
Old Jun 21, 2003 | 09:21 AM
mckdaddyfrd's Avatar
mckdaddyfrd
Thumbs up Engine ID
Only f.e. blocks have starters with three bolts 360/361/390/391/427 if your motor is original it might be a 361 that old only way to tell is by numbers. Oil pans for trucks sump was on both front and back depends on fwd or f100/f250/f350 but if oil drains on crossmember my guess not original.
Old Jun 21, 2003 | 11:26 AM
BB's Avatar
BB
Engine ID
Hi, the 2wd trucks have a front sump pan and the drain plug is on the rear driver's side corner of the hump, drains on the crossmember to keep it rust-free. I bet you got a 360.
Barry
Uni Moe
Oct 25, 2016 11:58 AM
davidrozeboom1
Aug 17, 2016 10:16 AM
hasteranger
Apr 29, 2016 03:28 PM
66ford400
Nov 2, 2015 10:59 PM
691/2F350
Nov 21, 2013 06:13 PM
