03 ball joint binding issues
Old Oct 27, 2013 | 08:19 PM
JWC 3's Avatar
JWC 3
Originally Posted by Restlesswildman
So lube before insertion and torquing?
I always pree lube components . U joints , ball joints .ect . I have seen many U joints come dry , with only a thin film of oil . Some ball joints are the same way ! The only suspension parts I do not pre e lube are sealed units . They should be factory lubed .
Old Oct 27, 2013 | 08:41 PM
BLADE35's Avatar
BLADE35
Originally Posted by reh4960
Just steering knuckle nothing else. moog torque specs are the same as ford on these ones 150ft/lbs bottom and 70ft/lbs top.
We are running out of Options VERY VERY Fast
I remember I had to use a Dremal tool to Clean the steering knuckle up a little so it would Fulley Seat the BJ into the Knuckle
I had my truck completely put back together then I greased the BJ and went for a Test ride and things was Fine
My Moogs had a little resistence when I turned the steering knucle by hand nothing out the ordinary and just fine Driving
SO Are you using a Ball Joint Press to Install them??? And able to get the spring clamp on them?? IIRC the Bottom ones
Or are you Beating them in with a Hammer
Old Oct 27, 2013 | 08:48 PM
Restlesswildman's Avatar
Restlesswildman
Oh I havent used a hammer in years on ball joints....but it does make for a fun time using one when your frustrated
Old Oct 27, 2013 | 09:13 PM
reh4960's Avatar
reh4960
I used a ball joint press harbor freight unit not very good but does work. I did have to hit the bottom one a couple times with a hammer though but had one of the pieces of the press on the joint and hit it with a hammer.
Old Oct 27, 2013 | 09:31 PM
BLADE35's Avatar
BLADE35
I see I had to hit mine But I did it with the press installed on it
I would turn it until I couldn't turn any more and give it a Whack on the screw end and turn more till I couldn't and repeat
That ranger I redid the Previous Guy Had No Press at ALL Just a Waffle Head Framing Hammer LOL and they were BEAT almost to the point of being unusable Plus they didn't Seat they seamed to work OK so I just reinstalled them
Needless to say the Owner was Pissed when I told them
But I had a Feeling yours were not like that since they were able to return them
Now is it Both SIdes that are hard to turn???
If so and with all the different Balljoints you tried Im thinking an Install Problem
Maybe the torq wrench is Off or something IDK
I wouldn't NOT Torq them though its Not a part you want to fail going down road Do you know anyone with a torq wrench you can borrow to torq and check your against??
How hard is it to turn??? they should have alittle resistence but not to hard
Old Oct 27, 2013 | 11:00 PM
reh4960's Avatar
reh4960
I will try another torq wrench. the resistance is enough that I have to use both hands to turn it.
Old Oct 27, 2013 | 11:32 PM
BLADE35's Avatar
BLADE35
Well 150 ft/lbs is getting Up there
I just don't know if a BJ isn't seating right or Torq wrench issues maybe Steering knuckle issues
But All those BJ Couldnt have Been Bad I would think anyways
Old Oct 27, 2013 | 11:38 PM
BLADE35's Avatar
BLADE35
[quote=reh4960;13674781]I will try another torq wrench. the resistance is enough that I have to use both hands to turn it.[/quote]
Ya that's Too Much WAY Too MUCH
Are you shure the Torq wrench is being set right???
Seams Like on mine one side is Ft/LBS and the Other side is Metric IIRC
Almost has to be torq wrench deal with the Above (Quote)
And just to be shure you torq out and then just tighten enough to get the Cotter Pin in the Castle Nut Right?? I fell your probably doing it right though
There should be Slight resistence and able to Move with 1 hand
ymurf
May 12, 2018 09:10 PM
cajun x
Nov 3, 2016 05:05 PM
WHEELZCRAZY57
Jan 1, 2015 05:21 PM
johntpr
May 28, 2013 10:57 AM
Plowdude
Aug 9, 2006 10:17 PM
