98 Ranger build!!
I have a 98 Ranger, which was bought 3 years ago, ghetto lowered. I lifted it back to stock after the suspension was torn up last year. Then earlier this year it was in an accident, I was given a haircut across the front. Here is its current state.
http://www.flickr.com/photos/55284637@N08/10505267623/http://www.flickr.com/photos/55284637@N08/10505089864/http://www.flickr.com/photos/55284637@N08/10505071966/
I have finally laid my hands on a donor truck in parts. I will be picking it up Monday. The frame has a bend behind the bumper. I will be rewelding the frame from the other truck onto it. Then making sure its straight. I will be taking the motor out to rebuild it while I have the front of the frame off. I am adding a whole lot of upgrades such as a bore, turbo, Stage 4 clutch, and other parts. Already setup for a 3 inch lift too. Check back for weekly updates!
The rest of the stuff sounds great. Good luck on the build. You are definitely more on top of this than most the morons who try to turbocharge on stock internals and stock injectors. The vast majority of those posting the ambitious projects here are in way over their heads.
There will not be much stock. Its receiving turbo forged 2.3L stock pistons, reg 2.3l rods, 2.3 crank, I have not situated on a cam yet. I am literally upgrading it all. No part left behind! Lol. Thanks for the support! I will be throwing up pics of the parts ranger tomorrow when I roll it in. Then I will get the trucks torn down and the motor and trans pulled out so I can begin reconstruction of them in the basement.
After the motor is out I can safely measure and cut the bad front end frame damage off, cut the good off the other, and weld it onto mine. Got lucky with the parts truck and its white to match my truck. So it works great!
On a cam, lots of choices, just let me tell you that the stock Ranger cams suck for turbo. They are built for low end torque, which you don't get because of the low compression, and right as the turbo is kicking in, the cam is starting to restrict. I have a Ranger cam in my -t-bird currently (mostly for the reliability of of roller cam), but want to switch to Bo-Port 1.5 at the nearest opportunity. Not sure what the cam options are on yours, I think the cams will work on the 2.5L head, but don't quote me on that.
Ya, there should be tons of choices, just gotta narrow down whats gonna get me the best output. I def don't want the stock cam. I need an upgrade for sure in that department. All depends on what gets me the best bang for my buck when its time to buy it.
Here is my parts Ranger. 99, no motor, trans, nor bed. Has every piece I will need to repair the frame and body.
http://www.flickr.com/photos/55284637@N08/10548131655/http://www.flickr.com/photos/55284637@N08/10548362623/http://www.flickr.com/photos/55284637@N08/10548128556/http://www.flickr.com/photos/55284637@N08/10548355793/
Pretty good for $370 after the cost of moving it to me.
Something I discovered also was when I was hit and looking at this parts ranger frame, there is this pinch up in front of the control arm mounting bracket and the bumper, will post a pic tomorrow. But the way it is pinched it looks like an on purpose design. In case of my kind of accident or head on accident it would collapse between the two pinches to decrease damage to the truck. Anybody know about this?
Again, will post some pics tomorrow once I have more of the ranger dismantled. Waiting on my friend to drop off his engine hoist for me to borrow, since mine was stolen. Lol.
http://www.flickr.com/photos/55284637@N08/11552517875/This is a pic of some of the outlined marks that I am assuming to be "clinched metal".
Am I correct in that is what that is?
http://www.flickr.com/photos/55284637@N08/11913348324/I ended up going with just cutting it off at a good spot where its not bent on my truck.
http://www.flickr.com/photos/55284637@N08/11913349784/Passenger side bend in main frame. I am cutting and rewelding the good one on in the middle of the control arm bracket.
http://www.flickr.com/photos/55284637@N08/11913354104/Here is the driver side bend further up. I am cutting and rewelding that at in the middle of the stabilizer bracket.
http://www.flickr.com/photos/55284637@N08/11913176623/This is before I removed the subframe off of my Ranger. Pretty nasty damage.
I will be installing brand new stabilizer links and will be putting on my new upper ball joints since I have the control arm already removed, this will make it easier to press the old ones out and the new ones in. I will be using the stabilizer bar from the parts ranger with its bushings since its in perfectly good shape. Other than those parts, there is nothing else broken on there. Weld the new portions of frame on, and then get everything bolted back together. That is if my welding guy shows up...
Welded the new stuff on, have to do some bending today as I put the fenders, hood, bumper, and grill back on.
http://www.flickr.com/photos/55284637@N08/11931114474/
I also have to bend the passenger side main frame end a tad to fit the bumper on properly. Oh boy! But other than that it is coming along greatly!
