Computer for 351W and AODE?
Old Oct 29, 2013 | 12:22 PM
Duvaren's Avatar
Duvaren
Originally Posted by jroehl
Is your ABS light on or flashing? Speedo bouncing?
Is your speedo correctly programmed for your tires?
Jason
No error lights are lit. Speedometer isn't bouncing.
At 30MPH on the speedometer, I am actually going 31MPH so it's pretty close.
Old Oct 29, 2013 | 12:24 PM
Duvaren's Avatar
Duvaren
Originally Posted by Conanski
You have some problems with your EFI or fuel system then, pull codes and make repairs to clear any codes that come up, and check that the fuel system delivers 40-45psi constantly under load,
There are no codes... But checking the fuel pressure does sound like a good idea.
Old Dec 27, 2014 | 07:27 PM
Duvaren's Avatar
Duvaren
Turned out the power problem was a mostly plugged catalytic converter.
rhinorocks220
Apr 24, 2018 07:48 AM
ng19delta
Sep 29, 2015 07:18 AM
truckhound
Mar 12, 2009 02:42 PM
wizzard351
Jun 26, 2008 11:25 AM
inasho
17
Jun 15, 2003 10:02 AM
