9 inch axle removal help
Old Oct 26, 2013 | 01:13 PM
51MercuryM1's Avatar
51MercuryM1
I purchased a 1964 9 inch from a Galaxie 500 to use in my 51 merc M1. The drums were seized onto the axle shaft and after trying everything, I was forced to break them up with a sledge to get them off. The axles turn freely and I have removed the 4 bolts that hold the shafts to the housing flanges. The axles should slide right out but the do not. Am I missing something?
How do I pull them if they don't budge?
Old Oct 26, 2013 | 04:52 PM
85e150's Avatar
85e150
It is possible something is wrong inside the axle, such as a twisted axle and spline. However, it is normal for these axles to be a bit tough to pull.
I used a slide hammer to pull mine. You can rap on the end of the axle a bit, then hammer with the slide hammer. I used a long bolt, large washers and a length of pipe.
Chris_ce
Offroad & 4x4
Jul 21, 2006 04:47 PM
Jim McAfee
Jun 12, 2006 08:52 PM
j_frank
Apr 27, 2006 03:03 PM
Rocking M
Jan 5, 2004 11:04 PM
TallGuy_Az
Mar 8, 2003 10:55 PM
