I've noticed lately that my fuel pressure is really jumpy at cold start, and stays jumpy until about the time the oil temp passes the coolant temp. The pressures fluctuate from around 45 up to the usual 60-62 psi while this is going on. Then all at once the needle quits bouncing and the pressures level out and behave normally again.
While the fluctuations are going on, Auto Enginuity cylinder contributions look normal. Shutting off one cylinder at a time has very little effect on the fluctuating pressures and doesn't seem to provide any clues toward a problem with a particular injector. I really thought I would find an injector that was hanging open, but that doesn't appear to be the case.
These fluctuating pressures show up on the electrical gauge in the cab and a small diameter mechanical gauge I have mounted under the hood, so it's not a gauge problem.
The voltage is doing its normal thing... I think it dances around in the hi 12s-low 13s while the glow plugs are cycling, and then jumps to hi 13s to low 14s when the glows shut down. So I don't think there's any correlation to voltage.
I'll have to put my ear near the Hfcm next cold start and have a good listen.
The truck starts great in the cold and runs normally. I wouldn't have a clue this was going on without the gauges.
And this morning, just to add another piece to the puzzle, the pressure stopped fluctuating when the coolant temp was only in the 150s. So it doesn't seem to be temperature specific.
Sounds like either a sticking regulator or a pump issue Wade. I know of one case where it was the HFCM when fluctuations like yours were experienced. The HFCM "listen" sounds like a good idea though. Maybe pull the regulator spring and look for excessive wear?
I rarely run WOT. Must be getting old. Wouldn't even want to try it for fear of breaking something. ;-) HFCM only has 40-50k on it, but could still be the problem.
The HFCM deduction sounds like the most likely suspect, since the problem seems to fix itself like someone flipped a switch. I'll pop the cover off the regulator tomorrow to have a look see, then listen to the HFCM closely if the pressure gauge needle is still bouncing at start up.
Sure helps to have a sounding board. Thanks a million!
Don't be scared. I run WOT at least once per trip. Since my truck does sit more than it runs . I would rather it break on a short trip than when towing out of town. Although I have no tuner. BTW do you have an air bleed for the sender? I was thinking maybe it is air in the lines that has to find it's way out which is when it stabilizes. Try locating the sender lower than the test port on the fuel pressure regulator test port.
Anybody ever had trouble with the schreader valve leaking on the IPT fuel pressure hose? There are definite bubbles coming out of it when I take the cap off.
Balloon test isn't the easiest thing in the world to do. I've been thru it once though on my old 03 and it worked great.
Maybe I better leave the leaky IPT fuel pressure hose alone until I have time for the balloon test. It'll keep me running instead of air locking a rail!
Ya there should be No Air Bubbles in there at ALL!!!
Definatly compression Gasses Unless its Sucking Air in somewhere
Usually we see High Fuel PSI when this Happens But that schreader valve must be Bleeding it OFF
and I just remembered that you can use that Yellow/Blue wire by the Heater Box passenger side it pulls apart and you can touch to Battery + side and that will engauge the starter and long as key is off position it wont start or run fuel pump
That wire is the Fastest way to do it sorrey I forgot about it then all you have to do is Pull cover off upper fuel filter
Apparently ITP Diesel is no more, or has turned into Strictly Diesel. Do they still sell the fuel pressure adapter hose with the schreader valve on it? If they do, I'm not having any luck finding it on their website.
