oil leaks found
Old Oct 26, 2013 | 09:55 AM
srteach's Avatar
srteach
oil leaks found
I've been so busy (80 hr/wk for 3 months) I didn't have time to look for the oil leaks I know I have. Laid off on Thursday, on Friday, I finally found the major one. Loose oil filter, not even hand tight, will definitely drop some oil.
Now for the leak in the valley....
Old Oct 26, 2013 | 08:42 PM
sand_fiend's Avatar
sand_fiend
thank god the filter didn't fall off..
Old Oct 27, 2013 | 09:20 AM
srteach's Avatar
srteach
Amen, brother. I would have been stuck doing an oil change at the side of the road, after the oil blew out.
Old Nov 3, 2013 | 07:28 PM
2000F250guy's Avatar
2000F250guy
le me know what you find on the oil in the vally as im in the same boat but still stuck working
Old Nov 3, 2013 | 08:30 PM
srteach's Avatar
srteach
Got busy again. Still need to look for the leak in the valley.
Old Nov 3, 2013 | 09:08 PM
Jesser02EX's Avatar
Jesser02EX
If you need any Valley help, let me know. I've tracked down three different valley oil leaks and fixed them all. I feel really good and working in the valley.
To start, get some blue shop towels and put them in the back (under the Turbo Pedestal), In the front and side of the HPOP, and in the center by the plenum boots.
All three will leak. The turbo is a pain because you have to connect the up-pipe collector blind and get the t-bolt v band clamp on. Not easy, but possible. The HPOP is a pain because it is a big mess and a lot of work. Again doable... The Plenums are the easiest, and cheapest. New boots and plenum inserts are a couple of hours and easy to do.
With the I/C Spider out, you can easily clean the valley to help find future leaks.
The turbo could be either the EBPV, or the actual turbo o-rings. Easy to rebuild and fix, but takes more then two hours.
Good luck and let me know if I can help. I've done all of this in the past two months...
c mobley
2015 - 2020 F150
15
Jan 22, 2024 01:24 PM
CrimsnTide
Oct 14, 2010 08:02 PM
echavez1981
2004 - 2008 F150
Jul 1, 2007 09:54 PM
99 7.3 towrig
May 6, 2007 10:10 PM
Beast12
Oil & Lubrication
16
Nov 3, 2004 07:57 PM
