Alternator just went up in smoke.......literally
Old 10-25-2013, 08:35 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I guess it's my turn for a new alternator. Started the truck to warm it up and it went up in smoke........LITERALLY
Old 10-25-2013, 08:38 AM
bismic's Avatar
bismic
bismic is online now
Received 2,515 Likes on 1,747 Posts
Ouch! (hope the FICM is OK - lol)
Old 10-25-2013, 08:43 AM
69cj's Avatar
69cj
69cj is offline
Tim, Didn't you have one of the a/m high outputs??
Old 10-25-2013, 08:55 AM
npccpartsman
It's not a DC, but it was an A/M 200 amp.
Truck didn't run but for a few seconds. I hope it's OK too. Seems to be a bearing.
Old 10-25-2013, 09:10 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
So you saw the smoke and Killed it
Old 10-25-2013, 09:18 AM
npccpartsman
Yup. Didn't even run for a minute.
Old 10-25-2013, 10:33 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
Sounds like the diodes shorted, it happens
Old 10-25-2013, 11:10 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Sounded Electrical to me too
Its went up in smoke almost to fast for a Bearing to cause anything is Possible though
My old OEM did something similar I never saw smoke but alt was grounded out and when I turned the Key on it would Drain Batterys Very Very Fast
Old 10-25-2013, 11:15 AM
POORBOY1964's Avatar
POORBOY1964
POORBOY1964 is offline
That sucks Tim how long had you had it?
Old 10-25-2013, 01:53 PM
npccpartsman
It's about 4 years old. The bearings went out. It should be ready now.
Old 10-25-2013, 02:49 PM
npccpartsman
Bearings, stator, and voltage regulator (just because I was open).
Mark, the FICM is fine. 47.5 to 48V on battery warming up and 48.5 on alternator after glow plugs kick off.
Old 10-25-2013, 03:06 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
cool did you rebuild it TIM/???
Bearing must been frozen in there??
Old 10-25-2013, 03:15 PM
npccpartsman
I didn't because the stator has to be soldered in IIRC, and I'm not good with a soldering iron. I have a shop here locally that's really good and really fast.
Ya know, Benny, I thought I heard it chirping when I first started the motor back up but it hasn't shown a bit of probem and it wasn't loose. That last run to Little Rock must have killed it cause it's been pretty much sitting ever since. Maybe that little "cold" snap we had locked it up and finished it off.
Old 10-25-2013, 03:22 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Im no good at Soldering either
Going to be doing the same thing you just did when mine goes out
Old 10-25-2013, 09:16 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
That set of connections takes a BIG iron. The Soldering gun is the way to go.
If and when you ever have to deal with that set of connections.
It's good that you saw it before the bearings locked and really made a mess.
Sean
Quick Reply: Alternator just went up in smoke.......literally
