front end disk brake conversion
Old Oct 25, 2013 | 10:04 AM
christurney77's Avatar
christurney77
Very nice looking truck!!!
Old Oct 29, 2013 | 12:54 PM
3Mike6's Avatar
3Mike6
Originally Posted by 47duallyFL
Thanks for weighin in, guys. To use what I have I would need either a donor hub with a larger bearing cup, or I need a smaller axle spindle. There needs to be a greater disparity between those two sizes to fit a tapered roller bearing.
I suppose you could have your spindles turned down.
Old Mar 19, 2020 | 06:01 PM
PetesPonies's Avatar
PetesPonies
Here is what I have done. I machined a bushing to fit the spindle and the A3 outer bearing. Here in the pic, the A3 is sitting on the spindle over the bushing. I need to swap the backing plate and mount the drum, to see if I need to shorten the bushing.
jamesobush
May 27, 2024 02:54 PM
wfowfo
1966 - 1977 Early Broncos
Mar 5, 2013 10:07 PM
rideorange
Jul 2, 2010 08:21 AM
tuekwik
Feb 17, 2007 03:15 PM
Kwikkordead
Oct 6, 2004 09:37 PM
