go fast cheap build
Old Nov 16, 2013 | 12:45 AM
  #46
Bonanza35's Avatar
Bonanza35
Following this thread. Like to see how it comes out. Just found this today.
Old Nov 16, 2013 | 03:14 AM
  #47
88 Ford IDI's Avatar
88 Ford IDI
What all do you have left to make and install on your turbo setup?
Old Nov 16, 2013 | 06:44 AM
  #48
88beast's Avatar
88beast
still need to install the turbo, with oil and boost lines. then intake, pyro relocation to the new pipe, install the wg, then make a down pipe.
ya i know its a lot to get done still but im hoping to have most of it done by sunday
Old Nov 16, 2013 | 08:02 AM
  #49
88 Ford IDI
It is easily doable. I look forward to the pics as it comes together.
Old Nov 16, 2013 | 09:27 PM
  #50
88beast's Avatar
88beast
thanks, it should be easy from here out just the time for stuff like the wastegate etc.
i got the turbo mounted tonight after bending the firewall more it all lined up fine.
finishing up tomorrow if the weather is nice they are calling for rain and thats no fun
Old Nov 17, 2013 | 05:52 PM
  #51
88beast's Avatar
88beast
finally done sort of
relocated vacuum tree.
turbo and up pipe in
misc pics after turbo went on.
the redneck tarp shelter to get out of the drizzel.
had to turn the truck around mid way through and it started to boost around 1800 from my guess.
still need to mount the wastegate and the pyro in the cross over pipe which i have a buddy welding up at work tuesday night. first test drive should be this weekend sometime.
and yes i know the oil line is tight, i am getting a 90 degree fitting to change that.
Old Nov 17, 2013 | 07:34 PM
  #52
88 Ford IDI
Make a video when you go for your test drive!!!
Old Nov 17, 2013 | 07:51 PM
  #53
88beast's Avatar
88beast
im planning on it along with a reving boost video
Old Nov 18, 2013 | 11:19 PM
  #54
88beast's Avatar
88beast
about cdr relocation is is best to run it pre or post turbo?
Old Nov 18, 2013 | 11:45 PM
  #55
88 Ford IDI
I think preboost. It will pressurize the crankcase post boost I believe.
Old Nov 22, 2013 | 10:43 PM
  #56
88beast's Avatar
88beast
video of the first turbo start is done.
boost gauge is not working though you can hear it spool, the video is hard to hear over the exhaust leak.
i think either the boost line is the wrong one (previously ran) or is kinked under the dash that plastic stuff sucks. there is no air movement on the line.
as for the exhaust leak yes i know, it will be fixed soon, the leak appeared when i went to the track and is coming from the pass manifold it may just need tightened.
i had a little oil blow out the back of the turbo say 3 large drops. idk if this is just being new seals or if its a real issue, hopefully someone can chime in here. i have a restrictor inlet i can toss in but would not want to burn it up either.
this is no dp so it does not have much back pressure the dp is on the way and will be going on next week, after it arrives. i will figure out the oil issue and get a drive video up next.
Old Nov 23, 2013 | 12:23 AM
  #57
racer30's Avatar
racer30
You don't have a restrictor in your oil line?... I looked all over and found for my HX40 they recommended a 1.5 mm restrictor. So I found a an4 plate to bolt to the turbo with a 1.5 restrictor. when I started mine I could get no Boost unless I was in gear revving into the torque converter. I rebuilt my turbo with a kit and lubed the seals (they look like little piston rings) with oil so mine spit out a little oil on start up too.
Old Nov 23, 2013 | 06:54 AM
  #58
88beast's Avatar
88beast
racer should that 1.5mm be good for the t70 too? and by the psi of the oil it shouldnt need one but im thinking at the higher rpms some may have seaped by, making one necessary.
thanks you for the help
Old Nov 23, 2013 | 12:20 PM
  #59
goose_ss4's Avatar
goose_ss4
looks sweet, but does sound like you got an exhaust leak buddy
Old Nov 23, 2013 | 04:35 PM
  #60
88 Ford IDI
Where did you get that center gauge mount? I have been lookin around for one for a bricknose style dash.
Also I agree about the exhaust leak. That will slow some turbo spool for sure...
