Axle ID
Y = 352 2V
R = San Jose CA Assembly Plant.
788742 = 1966, assembled December 1965.
129" Wheelbase.
8 = Springtime Yellow.
F100 2WD, 5,000 lbs. GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
B = Borg Warner T-85N 3 Speed Manual with Overdrive.
AXLE: Blank ~ Domestic Special Order.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
710216:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0216 = Domestic Special Order number, truck special ordered by original purchaser, not "bought off the lot."
Ford 9" rear axle standard equipment, Dana 44, Dana 60.2, Dana 60.3 rear axles, all with Limited Slip, all with inspection covers, all with 5 lug wheels, optional RPO's (Regular Production Orders).
Originally, there was a rear axle ID tag located under one of the bolts that retains the inspection cover to the housing. Cover is so caked with grease, I cannot see it.
It might be there...might not be, as these tags are usually missing today, which is (sadly) a common occurrence. People forgot to reinstall them when they put the covers back on.
No AXLE code stamped on the Warranty Plate: Truck ordered special by original purchaser, who requested a non standard rear axle not installed in F100's.
If a part failed, dealer contacted FoMoCo with 6 digit DSO, they look up the order number, pass the info back to the dealer what type of axle it is and where the parts can be found.
FoMoCo THREW AWAY the DSO records decades ago, so there's is no way to discover what rear axle it was ordered with.
It might be a Dana 60, normally only installed in F250's, but F250's have 8 lug wheels on a 6.50" bolt circle, while all 1953/79 F100's, some 1980/83 F100's have 5 lug wheels on a 5.50" bolt circle.
If you could get the numbers that are stamped on the ring and pinion gears, it might be possible to ID it. Ditto if the ID tag is still present.
F10 = F100 2WD
Y = 352 2V
129" Wheelbase.
710216:
Also saw some numbers stamped on ring gear, they are: 8 29 65 Dana 30360 A3D10 41-10
Any help would be appreciated. Thanks
Left (upper): Rear Axle ID Chart / Right: scroll down to Parts List #173
Left (lower): Parts List #173 continued.
Left (upper) Dana 60.2 - Parts List #168 / Right & Left (lower) Dana 60.3 - Parts List #173.
