How do you Repalce a fuel pump 99 E150 cargo through floor
Old Oct 22, 2013 | 05:02 PM
cali108's Avatar
cali108
Has anyone made an access's panel though the floor of their van to replace the fuel pump? I just need measurements where to cut.
The van wont start but it does runs on starter fluid...
4.2 V6 cargo 1999 e150..
Plus does anyone know if it has 3 line in /outputs or 2? they asked me that when ordering a fuel pump.
Old Oct 22, 2013 | 05:59 PM
maples01's Avatar
maples01
I believe WvVan did just that in his van: https://www.ford-trucks.com/forums/9...amper-van.html
Old Oct 22, 2013 | 06:07 PM
JWA's Avatar
JWA
Yep----page 12, post #441 to be exact. Great memory Maples01!
Are you sure its your fuel pump and not its fuse or relay causing this? Are you sure its not a clogged filter or the pressure regulator? Checked the inertia fuel cut off switch?
WVVan mentions the steps he took before determining if the pump itself was indeed bad.
Old Oct 22, 2013 | 07:03 PM
cali108's Avatar
cali108
Ill check the switch..
it has been intermittingly happening on startup were it wont start.
I swapped the relay with the a/c one it was the same..
thanks for the reply... I got it cut already how do you disconnect the fuel lines?
Old Oct 22, 2013 | 07:51 PM
WVVan's Avatar
WVVan
You'll want to read this post: Ford Truck Enthusiasts Forums - View Single Post - Converting a 1999 Ford E-250 into a camper van
You can probably do it without the cat.
Also you'll want to read this post from the same thread:Ford Truck Enthusiasts Forums - View Single Post - Converting a 1999 Ford E-250 into a camper van
Old Oct 22, 2013 | 08:20 PM
cali108's Avatar
cali108
Great post thank you!!
Are the lines 2 different sizes?
3/8 and 5/16 ?
Old Oct 22, 2013 | 08:23 PM
WVVan's Avatar
WVVan
3/8 and 5/16 ?
Yes. I'm guessing one reason is so you can't hook them back up the wrong way.
Old Oct 22, 2013 | 08:26 PM
cali108's Avatar
cali108
Originally Posted by WVVan
Yes. I'm guessing one reason is so you can't hook them up the wrong way.
ok great I'll get both tools. I will let you know how it goes... pick up the new pump in the am.. ty
Old Oct 22, 2013 | 08:28 PM
WVVan's Avatar
WVVan
The tool I bought at Advance Auto had a different size on each end so only needed the one tool.
Old Oct 22, 2013 | 09:01 PM
cali108's Avatar
cali108
what is fuse F20 ? 20amp fuse.. is blown!
I checked the fuel cut off switch under passenger dash and the button was pushed all the way in (no play) im guessing that's how its suppose to be
Old Oct 22, 2013 | 09:33 PM
WVVan's Avatar
WVVan
Electric Brake Controller
Old Oct 24, 2013 | 07:42 PM
cali108's Avatar
cali108
I'm up and running it worked like a charm.. replaced fuel pump, and I'm back to work, thank you... If your ever in Destin, Florida... I'll buy you a beer..
cheers
oh BTW That F20 fuse, I'm guessing that why my trailer brakes are not working
Old Oct 24, 2013 | 09:41 PM
WVVan's Avatar
WVVan
Glad I could help.
Old Nov 5, 2016 | 10:52 AM
Don W'mson's Avatar
Don W'mson
Great thread. I realize this is ancient, but would love to avoid dropping my tank since the van is in my driveway.
I'm trying to find the exact location of this. What is this part (circled) and how far from the left side. I have carpet and a small cabinet that will need to be removed. Any idea of the proximity (fore & aft from the filler door)?
Thanks in advance
Old Nov 5, 2016 | 08:24 PM
WVVan's Avatar
WVVan
That's the hump that covers the fuel filler hose. On the outside the gas cap is in line with it.
