Recommended Tire Pressure
Old Oct 22, 2013 | 03:42 PM
DoofusOfTheDay's Avatar
DoofusOfTheDay
Okay I have p235/75R15 sized tires on my 1995 F150 extended cab. I don't do any heavy hauling or any towing. I mostly use it just to bop around town. So specs say 35 PSI in front and 41 in back. Is that what I should be doing, given my light duty use of truck?
Old Oct 22, 2013 | 04:36 PM
RA31925's Avatar
RA31925
Are those the same size and load rating as what originally came on the truck? Then you can trust what the owner's manual says.
Otherwise, I would run close to what the sidewall max pressure says, unless I was unhappy with the ride quality (in which case I might go down 5 PSI).
Old Oct 22, 2013 | 05:04 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I never really pay attention to the door pillar sticker for tire pressure...on any vehicle.
Best thing, draw a chalk line across the tread of your tire, roll on it a couple turns at different PSI's, and find out witch one wears off the chalk line evenly across the tread, that will be your ideal tire pressure.
I found that on my 89 F150, 30psi in the back and 32 in the front is what it needs for the tire to wear down evenly.
Old Oct 22, 2013 | 05:31 PM
Conanski's Avatar
Conanski
Maximum tire pressure is only needed when the vehicle will be fully loaded, follow DieselJohn's advice to find the optimum pressure for even tire wear and maximum traction.
someday
Nov 29, 2019 03:47 PM
therigwelder
Oct 17, 2006 08:41 PM
Ron_1919
1997 - 2003 F150
18
Oct 20, 2004 06:16 PM
TexasGuy001
Nov 19, 2002 08:22 AM
