7.3IDI while glow plugs cycle, tach and battery gauge flicker up and down.
When I turn the key on to cycle the glow plugs on my 1990 250 7.3l IDI the glow plugs cycle but when the wait to start light goes off the tachometer and battery voltage gauges go up n down synchronized for close to 45 seconds even if it is running or if I just keep the key turned in the warmup position..
Okay so it's normal for my tachometer and voltage gauge needles to go up n down while they cycle? With vehicle not running the tachometer should move?
My truck does the exact same thing, so I assume it's normal. It'll also bounce around a little bit after the truck is started, when the GP's click on and off. Once the GP's stop cycling, the tach and voltmeter go back to normal.
1985L8000cat3208
02-01-2016 08:38 AM
marauderx
01-07-2013 09:09 PM
