Sponsored by: Auxito
Abs
Old Oct 19, 2013 | 08:15 PM
slickg's Avatar
slickg
Abs
I have a 97 f-150 that I bought and the the guy put brand new brakes on the truck and now the abs light is on
Old Oct 21, 2013 | 10:50 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Welcome to FTE!
Moved to tech forum from General Chapter discussion
Old Oct 21, 2013 | 09:42 PM
steve(ill)'s Avatar
steve(ill)
There is a speed pickup on each front wheel that measures wheel RPM (basically). The computer compares the two fron wheel sensors to the third sensor on the rear axle pumpkin to see that all are rotating the same speed. The ABS light comes on if one sensor is not working. Turn on the key and the light comes on. Start truck and the computer will check continuity thru the wires. The light goes out in 5 seconds. If the light does not go out, you have damaged the wire pins when plugging them together on the front wheels. If the light goes out, then drive the truck. The computer compares speeds when you get to 5 MPH or so. If the light comes on after that, then one of the front sensors is damaged and will not read right, but does have continuity.
fordguy2236
1997 - 2003 F150
Aug 28, 2012 06:15 PM
peter p
1997 - 2003 F150
Jan 25, 2010 10:26 AM
94SILVER250
Electrical Systems/Wiring
Jan 10, 2005 09:55 PM
laidbacksouthern
1997 - 2003 F150
Nov 23, 2004 03:56 PM
prazeau
Jul 28, 2003 12:46 AM
