Sponsored by: Real Truck
fueling troubles
Old Oct 18, 2013 | 11:12 AM
Bill Croft's Avatar
Bill Croft
fueling troubles
I have a 2001 F-350 7.3 diesel SD. I can count faster than I can fuel it, does anyone have a suggestion, Was there any known problems with the fillier neck or is it just my truck.
Old Oct 18, 2013 | 12:29 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Our 02 F250 V10 does the same thing. I heard once before a supposal anit syphon ball is messing it up but I took the 02 apart once and found nothing. Hopefully somebody will chime in.
Trav
Old Oct 18, 2013 | 12:54 PM
Bill Croft's Avatar
Bill Croft
While looking in the filler neck Ive noyiced that the hose looks to be colapsed a bit im going to try wrapping and clamping it to open it fully and see if that helps.
Old Oct 18, 2013 | 01:21 PM
Redneckfordf2502002
cool let me know if that works.
Trav
Old Oct 18, 2013 | 01:52 PM
GregsSD's Avatar
GregsSD
Yes, make sure the hose is not collapsed, also look under and check the vent hose to make sure it is not kinked or blocked.
And for diesels, you can do the Harpoon mod which will let your tank fill all the way without having the nozzle click off early! https://www.ford-trucks.com/forums/2...ml#post1762191
wade2000
Car/truck Buying Advice
Nov 29, 2014 04:09 PM
burgf250
Oct 23, 2010 10:00 AM
4griffins
17
Jan 26, 2010 07:12 PM
bama210
Modular V10 (6.8l)
24
Oct 2, 2008 07:39 AM
jimcald
Nov 16, 2000 02:42 PM
