02 V-10 died swapped 02 7.3L Diesel in...electrical?
So this didn't happen to me, but I am looking at a truck that this happened to. might be a good deal depending on your answers.
V10 died and the guy swapped in his 7.3L...The truck runs great, except the electrical, gauges, etc.
How hard would it be, or more likely, how much time and money would it take a mechanic to rework the electrical?
Both trucks were 2002.
Any ideas?
Thanks!
Any ideas?
Thanks!
It would have to have the diesel PCM in it already, or it wouldn't be running. The cluster is completely different in the diesels, so I would say it would need the wiring harness and gauge cluster out of a diesel as well. 2002/2003 should work. Can't use one from the older trucks -- they are different.
I think I saw that on CL a week or two ago. I personally would offer much less, maybe 6-7k. I just don't think it is worth 9k. If it had a bad v10 in it still it wouldn't be worth more than a $3-4k, I dont think throwing a used psd in makes it worth 5k more considering having to deal with the electrical issues. Now if it was swapped and everything worked perfect then maybe.
As far as the insturment cluster, I can honestly say I haven't been in the cab of a later model gasser SD. Didn't know they were different. Sounds like a visit to the parts department is in order to see what parts and wire harnesses interchange and which don't. You could get prices that way too.
