Alternator upgrade.
Old Oct 17, 2013 | 09:40 PM
73 ford guy's Avatar
73 ford guy
Alternator upgrade.
My alternator just went flat on my 96 f350 with a 5.8L.
Any common upgrades with donor parts to upgrade like a 3G or whatever. Stock replacement is a 95 amp. Just looking for any ideas,tips
Old Oct 17, 2013 | 10:08 PM
Encho's Avatar
Encho
The Southernmost Mod
Yes, the 95A is already a 3G, albeit a small case one, so you already have the proper harness to install a bigger alternator. You can search for a large case 3G of the same configuration as yours and you'll have an 130-160A output. The large case is easy to tell apart because there are three radial rows of 2 holes in the front face of the case, just behind the pulley (yours has 4 holes in the same arrangement). Fixing your current alternator probably is a $10 ordeal (brush replacement, maybe a regulator replacement) and a good measure to keep a spare at hand.
Old Oct 18, 2013 | 08:34 AM
73 ford guy
Is it bolt on if I pull one from like a f450 or ambulance or something with the larger case
Old Oct 18, 2013 | 10:10 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You'll likely need to grind the mounting bracket to clear the larger (148mm) body of the 130A alternator.
There are pictures on the RJM/oldfuelinjection website.
http://oldfuelinjection.com/?p=75
(Edit)
I see you have a '96 side mount alternator.
Sorry to add confusion.
robjs111
1978 - 1996 Big Bronco
Jun 10, 2014 06:20 PM
patjr_45
16
Mar 14, 2009 08:34 PM
DeepDoc1
Mar 9, 2007 09:09 AM
superbepro
Oct 30, 2005 07:01 PM
Ryan50hrl
Apr 13, 2004 01:07 PM
