HPOP
Old Oct 17, 2013 | 05:00 PM
tcjhkbjt's Avatar
tcjhkbjt
HPOP
where is the cheapest place anyone has found the HPOP
Old Oct 17, 2013 | 06:13 PM
BLADE35's Avatar
BLADE35
Tousley ford
IIRC its now Auto Nation
Do you know what HPOP you need
Old Oct 17, 2013 | 09:10 PM
tcjhkbjt's Avatar
tcjhkbjt
Originally Posted by BLADE35
Tousley ford
no new.to the diesel world, I didnt know there was different ones. I have an 04 f250 wirh the 6.0 powerstroke. does that help?
Old Oct 17, 2013 | 09:17 PM
m-chan68's Avatar
m-chan68
The following are the Ford part numbers for the parts you need, assuming you have a late-build 2004 6.0L (with a vehicle build date later than September 29th, 2003).
4C3Z- 9A543-AARM High Pressure Oil Pump
3C3Z-9C968-AA (CM-5054) IPR Valve
Old Oct 18, 2013 | 07:22 AM
tcjhkbjt's Avatar
tcjhkbjt
thanks, my ICP is on the passenger side valve cover if that also helps.
Old Oct 18, 2013 | 08:00 AM
mustang_309's Avatar
mustang_309
If your ICP is on the passenger side valve cover it is a late 04 model, Mchan gave you the part numbers for the late 04 model.
Old Oct 18, 2013 | 08:23 AM
tcjhkbjt's Avatar
tcjhkbjt
ok thanks guys
jblksmith1
Nov 9, 2014 03:12 AM
rsplash40
Dec 26, 2011 11:16 PM
scottman70
Aug 10, 2007 03:18 PM
6.0Diesel
Jul 29, 2004 10:36 AM
RyanF
May 9, 2004 08:16 AM
