Hear is what I have done. I changed both primary and secondary fuel filters with motorcraft. I also changed the secondary filter cap and replaced both batteries. It will turn over real strong but will not crank. I checked to see if fuel was flowing into the secondary fuel filter housing and it was. I am at a loss as to what the issue could be. Any other help is greatly appreciated.
ScangaugeII or DashBoss or that other one GUYS?? it was cheap and soundwd like did a lot
ANY DTC??
ANT Recent Work??
Blade35, will the scangauge II tell me if the FICM or HPO is bad? I found a new one at Advance for $159.00. Seems worth it if it tells what I need to know. Please get back to me ASAP and I will pick it up tomorrow. Running out of vacation time fast. Need to get this truck fixed soon. It just seems like it is not getting fuel to the cylinders.
