Harmonic Balance Removal
Old Oct 17, 2013 | 09:17 PM
C350CREW's Avatar
C350CREW
After I posted that reply, I did some research and found out what it was.
Thanks for all the info, that is what is great about this site, you guys will offer up suggestions to possibly save from having to go back in or redue something. I am not afraid to try and fix anything, I just dont have the experience on the diesel engines. I have learned alot on here and have alot more to learn.
Thanks again for all the help. I will keep you posted on the progress.
Old Oct 17, 2013 | 10:45 PM
fordman67's Avatar
fordman67
so,what is wrong with the old balancer anyway with that low mileage..
Old Oct 18, 2013 | 03:05 AM
tiopet's Avatar
tiopet
How do you know the balancer is bad?
My van has just passed 248000 miles.
It's rattling and shaking, but still running.
I tried to record a video, but the loud sounds from the motor made the sound almost disappear in the recording. Or could it be the frequenzy of the turbo that cancels the sound.
I used a cheap china dash camera, which maybe explains it.
Will try my wifes JVC camera one day.
Old Oct 18, 2013 | 08:06 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
Originally Posted by fordpride
With just a100k I wouldn't touch the lpop
to piggyback on this discussion - as I know the harmonic balancer is bad on the engine i'll be rebuilding/refreshing soon: how about doing the LPOP at 200k?
if i'm doing the harmonic balancer then, should I do the LPOP as well at that time? i think i have to do the crank seals (front and rear) as well, so it sounds like i'll have to take the pump off to do that anyway, right? might as well replace while its off?
Old Oct 18, 2013 | 09:22 PM
C350CREW's Avatar
C350CREW
Trying to load some pics, if I can figure it out. They will show what is wrong.
Old Oct 18, 2013 | 09:36 PM
fordpride's Avatar
fordpride
I'd change a 200k pump if I was doing that much work on a engine.
Old Oct 18, 2013 | 09:42 PM
C350CREW's Avatar
C350CREW
Still having issues with the pictures. There are pieces of rubber missing on the front ring.
JP-I would definitely do the front crank seal and lpop while the balancer is off. Too much work getting to that point not to go ahead and change.
Old Oct 18, 2013 | 10:05 PM
fordpride's Avatar
fordpride
Upload pic to photobucket then copy and paste img code here
Old Oct 18, 2013 | 10:33 PM
C350CREW's Avatar
C350CREW
This is the bad one, obviously.
http://i1287.photobucket.com/albums/...ps1fc29c04.jpg
This is the back side, bottom half is the wear ring.
http://i1287.photobucket.com/albums/...psc7454360.jpg
This is the new balancer, the wear ring is not needed, will not fit on the new one.
http://i1287.photobucket.com/albums/...ps6b7e1281.jpg
This is the wear ring. The old balancer has one, the new balancer does not need one.
Old Oct 19, 2013 | 10:27 PM
C350CREW's Avatar
C350CREW
Crank seal installed, used a 3" water fitting as a driver. Balancer on, went on easy with the install tool from Autozone. Had to make a spacer, the nut that you use to drive the balancer on went up inside and could not be reached even with a deep well socket.
Now need some fittings and bolts to mount new IH water pump, flush, and add new coolant.
Old Oct 20, 2013 | 10:54 PM
fordman67's Avatar
fordman67
hoooley moley,that balancer was trashed! WOW,glad you caught that before it ruined the bottom end.
Old Oct 21, 2013 | 06:37 AM
OldWoodsDiesel
thanks for the pics, Randy - I've been curious what the inside of those things looked like. i'm also curious what makes them go bad? seems like most times they last forever, other times, they die at a 'mere' 100k miles or so (I still love that 100k miles is nothing on these trucks).
and thanks for the input guys - i'm pretty sure the balancer was bad on the engine in my red truck, and now that its getting yanked and rebuilt, its time to replace it - and everything behind it!
Old Oct 21, 2013 | 12:36 PM
  #28
C350CREW's Avatar
C350CREW
No Idea what makes one go bad, probably a defective part. When I put a water pump on my other truck at 160000 I didnt notice anything wrong with that balancer. Cant say I actually looked it over good, but it should have been obvious like this one.
I would definitely at least pull it to put a new crank seal and check the lpop. If it has a lot of miles, it wouldnt hurt to go ahead and put a new balancer on.
I hope this did not do any damage, hopefully it hasnt been that way too long. When I got the truck it had 92000, now 103000. Not bad for 5 years. This one is my baby.
fordboy300
18
Feb 9, 2020 12:30 PM
dmueller71
Dec 18, 2010 10:49 AM
Dan Edick
18
Jul 31, 2008 11:01 PM
theGman
64
Dec 28, 2007 09:02 PM
