Gauges dont work?? Help!
Old Oct 16, 2013 | 07:26 PM
Nicktitan's Avatar
Nicktitan
None of the gauges in my dash function, save for the speedo. Anybody know what might be the issue here??
Old Oct 16, 2013 | 08:47 PM
Gembone's Avatar
Gembone
check your instrument panel voltage regulator. take a look HERE.
also make sure you have power and ground to the cluster.
Use a multimeter to check for signal from the gauges.
do the dash lights work?
Old Oct 17, 2013 | 01:28 AM
Nicktitan's Avatar
Nicktitan
Yeah, the dash lights work. Some times you gotta wiggle the **** a bit to get them to come to, but they do work.
Old Oct 17, 2013 | 03:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Gembone
check your instrument cluster voltage regulator (ICVR). take a look HERE.
OP has a 1970 F250.
1970 F100/350 & Econoline: Printed circuit boards (with Oil/Amp Gauges or Oil/Amp Warning Lamps) & ICVR: 1970 only.
Old Oct 17, 2013 | 04:50 PM
JEFFFAFA's Avatar
JEFFFAFA
I'd bet the curcuit board on the back of the cluster is dried up and cracked. OP, with a flashlight look at the back of the cluster behind the dash. The curcuit boead is a thin plastic film with copper traces in it that links the gauges to the dash wiring. It gets dried up and cracks through the copper traces.
Old Oct 17, 2013 | 05:33 PM
Nicktitan's Avatar
Nicktitan
I'll check it out, thanks
Edit: How much of a pain is it to fix/replace one of these, in case it is busted?
Also, would the speedometer and lights (including warning lights) still work, even if it was messed up??
Old Oct 17, 2013 | 06:25 PM
JEFFFAFA's Avatar
JEFFFAFA
Sure could. Depends where the board may be cracked. But now that I know you have warning lights now I think your problem may indeed be in the dash's voltage regulator.
Cluster would have to be removed but that is easy. Speedo is mechanical cable.
Old Oct 17, 2013 | 08:58 PM
NumberDummy
C9AZ-10804-A .. ICVR - Instrument Cluster Voltage Regulator (Motorcraft GR-512).
1970 F100/350 & Econoline // 1969/73 Mustang/Cougar / 1969/78 Galaxie/LTD / 1970/77 Maverick/Comet / 1975/80 Granada/Monarch.
DOTZ-10K843-B .. Printed Circuit Board-Use with Oil/Amp WARNING LAMPS / Marked: DOTF-10C956-B / Obsolete ~ 5 available NOS
1970 F100/350 & Econoline.
Old Oct 18, 2013 | 12:08 AM
Nicktitan's Avatar
Nicktitan
Any way to check the regulator, besides dropping cash for a new one and seeing what happens?
And thanks for the parts info!! Thats very good to know
Old Oct 18, 2013 | 08:46 AM
MavSprint's Avatar
MavSprint
See Post #4 in this thread. Instrument Panel Voltage Reg. - Vintage Mustang Forums
Old Oct 18, 2013 | 09:34 AM
Gembone's Avatar
Gembone
From my earlier link
You can test the IPVR without pulling the instrument cluster. Tilt the seat forward and pull off the orange wire from the fuel tank sending unit. When you probe the connector, your test light should flash on and off. You can also do the same test under the hood. Pull off the sender wire from the temperature sender and/or the oil pressure sender and probe those connectors...they should flash too.
Old Oct 18, 2013 | 12:01 PM
JEFFFAFA's Avatar
JEFFFAFA
This I did not know Greg. Good job! Thanks for this info.
Old Oct 18, 2013 | 12:04 PM
Gembone's Avatar
Gembone
Just sharing info I have found in my pursuit to fix my fuel gauge.
BEN WHEELAN
Feb 26, 2018 11:29 AM
wmring
May 1, 2013 12:03 PM
Bad 674x4
Mar 6, 2013 09:29 PM
alhorgan
Sep 25, 2012 10:18 AM
westtex
Jun 18, 2012 03:49 PM
