Instrument panel
Old Apr 30, 2013 | 01:36 PM
wmring's Avatar
wmring
Instrument panel
Oil pressure and amp meter not working in most cases can u replace the sending in and check. The wiring?
Old Apr 30, 2013 | 02:01 PM
JEFFFAFA's Avatar
JEFFFAFA
Your truck had the gauges from the factory correct? If it had idiot lights and you are adding in a used gauge cluster the wiring is different. If your truck did come with the gauges your problem is most likely in the curcuit board on the back of the cluster. It is the part which powers all the gauges and lamps with copper traces rather than wires. After years the clear plastic starts breaking and the lamps/gauges don't make good contact.
Old Apr 30, 2013 | 02:18 PM
wmring's Avatar
wmring
That is good to know, the truck came with the standard gauges to on each side of the speedo. fuel guage work mostley but the oil pressure and and amp meter do not.
Old May 1, 2013 | 02:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1TZ-10K843-A .. Printed Circuit Board-Use with Oil/Amp Gauges / Marked: D1TF-10C956-AA / Obsolete
Applications: 1971/72 F100/350 & 1971/74 Econoline.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
HIGH BUCK!! BOB ALLEN FORD in Overland Park KS has THREE = 800-676-0675.
Old May 1, 2013 | 12:03 PM
wmring's Avatar
wmring
Thanks much have a great day
Nicktitan
Oct 18, 2013 12:04 PM
Visine
Oct 10, 2013 09:57 AM
Bad 674x4
Mar 6, 2013 09:29 PM
tinman52
52
Dec 30, 2012 09:57 PM
FitchBanjos
23
Mar 22, 2008 04:58 PM
