Heater Core Bypass
Old Oct 16, 2013 | 04:57 PM
mpkeith's Avatar
mpkeith
Heater Core Bypass
Hi guys!
My heater core blew the other night and I need a quick fix. I don't have time to pull the dash and I can't afford to have it done for me either right now. I'm in Florida, so I really don't care about having heat, and this is a POS so I don't care about looks, either. It's my only vehicle, though, so I need to get it back on the road asap.
After looking at options I decided to bypass it, but there seems to be 2 ways of doing this... looping or capping off. I've heard that looping can cause issues so was going to cap it off. I found this video that looks super easy to do, but just wanted some opinions before I do this. It's basically cutting the hoses in the middle, capping them off with copper and zip tying them together so they don't flop around.
Should this serve my purpose? Thanks ahead of time!
Old Oct 16, 2013 | 05:08 PM
Eddiec1564's Avatar
Eddiec1564
Its best to loop the coolant. Some engines use it as a coolant bypass to alow the coolant to flow when the t-stat is closed.
During the summer I loop the heater lines to bypass the heater core. It gets rid of the heat soak from the heater core and gives better AC for us Floridians!
Old Oct 16, 2013 | 05:09 PM
Diesel_Brad's Avatar
Diesel_Brad
Agreed. LOOP IT
Old Oct 16, 2013 | 05:40 PM
mpkeith's Avatar
mpkeith
Appreciate the feedback, guys!
Old Oct 16, 2013 | 05:50 PM
'89F2urd's Avatar
'89F2urd
its soooooooooooooooooooooooooo easy to get to the heater core in these trucks. having done a few, I could probably do it in 10 minutes.
not as quick as looping it, but once it's done, it's done.
Old Oct 16, 2013 | 06:15 PM
bashby's Avatar
bashby
I once used a deep well socket and hose clamps to loop a heater core so the customer could drive it until the part came in.
Old Oct 16, 2013 | 06:55 PM
mpkeith's Avatar
mpkeith
89F2urd, I was under the assumption I needed to pull the whole dash out to get to it. Am I able to get to it through the engine compartment? The black box next to where the hoses go into the firewall in this picture isn't it, is it?
Old Oct 16, 2013 | 07:05 PM
86 FORD GUY's Avatar
86 FORD GUY
no you get it out through the glovebox opening the early 80 's were easier
Old Oct 16, 2013 | 07:32 PM
bashby's Avatar
bashby
Theres an access panel after you take the glove box out, it's a 1-2 hr job tops.
Old Oct 16, 2013 | 08:36 PM
Diesel_Brad
And that is taking brakes for 4-5 beers
Old Oct 16, 2013 | 08:57 PM
87-XL-Squared's Avatar
87-XL-Squared
Yeah, what he said.
I just did one on the blue '87 and I was amazed at how easy it was. I had a '74 before this so I was expecting the worse.
Its as simple as removing the glove box door and unscrewing 7-8 screws. Then remove access cover. There it is - the heater core.
It's literally a 15-minute job - 30 if you loaf.
But by all means if you need to bypass it - which I did until I could go get a new heater core - then simply loop the hoses.
grip1968
Mar 22, 2020 10:46 AM
Tom on Roadside
Oct 9, 2017 05:34 PM
ddeflyer
May 31, 2015 04:35 PM
ford4her
Oct 12, 2008 12:31 PM
lowdive
1983 - 2012 Ranger & B-Series
Sep 22, 2004 05:29 PM
