Heater Core
Old Oct 24, 2013 | 02:16 AM
grip1968's Avatar
grip1968
Heater Core
I have a 98 ford expedition XLT 4.6L, back in July I started smelling coolant and the windows was fogging up inside the truck, and the it over heated, I took it to my mechanic and he bypassed the heater core for me. but now its getting cold I need my heat. Now I had the heater core replace 2yr ago. Im shock to see it went out again, My question is should I have it power flushed real good to see if it lossen up anything in the core, or should I replace it again. Also do I have 2 heater core's or 1????
Old Oct 24, 2013 | 09:14 AM
alloro's Avatar
alloro
It's highly unlikely the heater core itself is leaking after only 2 years. I've seen the heater hose couplers leak and spray coolant towards and into the firewall openings the heater core tubes stick out of. I'd hook it back up and look for leaking at the couplers.
Old Oct 24, 2013 | 09:59 AM
grip1968's Avatar
grip1968
That's what im thinking of doing cause I cant see it going that fast unless the shop did a shady job on the heater core and the hoses too. , should I flush the heater core too. also do I have 2 heater core or 1...
Old Oct 24, 2013 | 12:38 PM
alloro's Avatar
alloro
You can flush it since you're taking it apart, but I wouldn't expect there to be any clogs after only 2 years. Before attempting to remove the heater core, first test it for leaks by pressurizing it and seeing if it holds pressure, or vacuum depending on how you test it. If it holds then the heater core isn't the source of the leak.
Old Oct 25, 2013 | 08:11 AM
c_hohensee's Avatar
c_hohensee
If you have the rear heat/air option you have 2 heater cores.
Old Mar 22, 2020 | 10:46 AM
Dan P's Avatar
Dan P
Interesting responses...stuff I wouldn't have thought of....When it gets hot here in N. Ca I'll mess with the bypass idea to see if it makes a difference!
thanks all!
Dan
midsouth
Nov 13, 2017 03:57 PM
73Riviera
Sep 8, 2006 02:08 PM
Tazzmann
Oct 11, 2005 08:38 PM
lowdive
1983 - 2012 Ranger & B-Series
Sep 22, 2004 05:29 PM
