4x4 conversion
Old Oct 20, 2013 | 11:55 AM
Evan_P's Avatar
Evan_P
I wouldn't run anything bigger than 35" on a TTB, and even then personal experience throws me back to 33's. With 35's I got terrible mileage, had NO power with my gearing and it would never stay properly aligned for more than a couple hundred miles. Not to mention that they were killer on the power steering (on it's 5th steering gearbox and its on its way out) and the rest of the front end. In fact, shortly before I started driving the truck the whole front end had to be rebuilt as the 35's wore everything out. I will never go larger than 33".
Old Oct 20, 2013 | 11:18 PM
Jarryd's Avatar
Jarryd
With that said, it may be worth it to just see about getting a quality lift with better travel. I'm not overly concerned with too much more height on the truck but I do like the look of bigger tires. The 33s look like they should have been on there stock after looking at them so long. Do you have a picture of your setup Evan?
Old Oct 20, 2013 | 11:39 PM
Evan_P's Avatar
Evan_P
I can grab better pictures tomorrow, but for now here is what I have.
The front uses axle pivot drop brackets like any other lift. However, instead of drop brackets for the radius arms, they are longer than factory and use factory brackets.
If there is anything in particular you would like to see let me know.
The rear uses factory blocks with lift springs. One thing to note is than the new Pro-Comp system, which is what i have, uses blocks now instead of springs.
And just an idea of how it sits with 33's.
Old Oct 20, 2013 | 11:43 PM
Evan_P's Avatar
Evan_P
Here what the old 35's looked like.
Old Oct 21, 2013 | 02:13 AM
Bob Gervais's Avatar
Bob Gervais
Not long at all with 1/2 ton running gear...
Old Oct 21, 2013 | 07:27 AM
Jarryd's Avatar
Jarryd
How much lift is that?
Old Oct 21, 2013 | 07:28 AM
Jarryd's Avatar
Jarryd
And I'm guessing the aftermarket radius arms eliminate some rubbing issues?
Old Oct 21, 2013 | 07:58 AM
Evan_P's Avatar
Evan_P
That is a 4" lift. I still get running issues at full lock.
TheKirbyMan
Aug 17, 2009 03:20 AM
evilbeast
Offroad & 4x4
Jan 5, 2008 02:04 PM
OffRoadF-150
Offroad & 4x4
43
Jan 2, 2006 01:10 AM
Tom92F150
Offroad & 4x4
15
Dec 11, 2004 04:07 PM
rkshipley
Nov 29, 2004 06:52 PM
