77 Heater ?
Old Oct 16, 2013 | 10:50 AM
Az58Cameo's Avatar
Az58Cameo
77 Heater ?
The Heater outer Box or Plastic housing under the hood has been cut up
by the P/O on my 77 super cab,why i don't know, but thinking maybe to replace
the heater core?. My ? is, anyone make a replacement to replace existing or
do i have to look at something like vintage air ?
I have the motor out right now and am was thinking now is the time to get
this area fixed.(Trucks Engine that is)
Also can the inner fender's be pulled out without removing the outer fender's?
Thanks,Allen
Old Oct 16, 2013 | 11:06 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The way you're describing it, you have factory air. With the exception of the 78-79 Hi-Lo comfort air heater if you have just a heater, the assembly is up under the dash. If you've got a big box sticking in the engine compartment then you have factory air.
You should be able to find the evaporator housing in a local salvage yard. The 73/mid-75 are a little different than the mid-75/up units.
Old Oct 16, 2013 | 11:08 AM
ford_pickup's Avatar
ford_pickup
also, no the inner fenderwell actually are what the hood hinges bolt to, so if they need to come off, the whole front clip needs to come off
Old Oct 16, 2013 | 11:32 AM
Az58Cameo's Avatar
Az58Cameo
Thanks Guys
Yes,it does have factory air! man the P/O really hacked it up!! Can i ask! does the blower motor come out from under the dash or from under the hood?
Looks to me like its in the box under the hood, but how do you remove the outer cover as
it looks like that cover is factory riveted on?
I will try and post picture's of it when i get home.
and i had a feeling the inner panels would not come out unless the sheet metal was removed.
Thank you guy's very much for your Time!
Really do appreciate IT!
Allen
Old Oct 16, 2013 | 11:46 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The outer cover is riveted and isn't supposed to be removed. The blower motor and heater core are designed to be serviced from underneath the dash. In fact there used to be a decal on the evaporator housing saying as much.
Old Oct 16, 2013 | 11:50 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a link to a step by step on servicing the a/c heat system
NORTH COUNTRY SPECIALTIES ®
Old Oct 16, 2013 | 01:13 PM
tylert1976's Avatar
tylert1976
I have pulled my entire AC system to go heat only (hitting the salvage yard on Nevada day--half price for everything). If your box is too damaged to repair, we can work something out. PM me.
Old Oct 16, 2013 | 01:40 PM
Az58Cameo's Avatar
Az58Cameo
WoW, Mike o, That is exactly what i have, and I thank you so much!!!!
That is a HUGE and BIG Help!!!!!!! I would have probably screwed it up even worse if you had not posted this! Thanks So Much!
Allen
Old Oct 16, 2013 | 03:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Allen
Glad to help, hope you get it fixed.
Todzila
May 25, 2014 03:32 PM
Notmeofficer
Sep 15, 2012 01:49 AM
460
Dec 8, 2005 05:11 AM
Beast12
Oct 27, 2004 05:32 AM
Montypython
Oct 9, 2004 10:12 PM
