Heater core questions, please help...
Old 12-04-2005, 11:25 PM
460's Avatar
460
460 is offline
Link to the tech article for reference: Clicky Clicky
Ok, I have a '79 F150 with A/C. I'm thinking the heater core is bad because it fogs the windows and smells like antifreeze.
So, I printed a copy of the tech article to bring out to the garage with me, but now I'm lost, and the truck is half way apart. I will quote, then ask my question under it. Below that is some links to pics of my mess, feel free to draw arrows to the parts if you want. My email is mudmachine @ gmail.com
13. Remove the plenum by extracting the two screws above the transmission tunnel that hold the plenum to the dash.
What part is the plenum? And where are the two screws?
14. Remove the screws securing the evaporator.
Is there 6 screws to remove? The bottom two have the heads rusted off and I can't get a wrench on them, any ideas?
15. Pull the evaporator from the case and secure it above the case.
What is the "case"? And does the evaporator come out under the dash or under the hood? Does the outer housing under the hood stay mounted to the firewall?
http://i4.photobucket.com/albums/y11...2-03-05007.jpg
http://i4.photobucket.com/albums/y11...2-03-05006.jpg
http://i4.photobucket.com/albums/y11...2-03-05001.jpg
Sorry for so many questions, and thanks for any help you can give.
Old 12-04-2005, 11:40 PM
timothy47129's Avatar
timothy47129
timothy47129 is offline
If you didnt get the tech info from www.autozone.com I would try there.The plenum is the box assembly you see under the hood.
Old 12-05-2005, 08:26 AM
76supercab2's Avatar
76supercab2
76supercab2 is offline
No, the plenum is in your second picture. I can't remember why the instructions say to remove it. You can try to skip that step and see if it's necessary.
In step 12, you need to remove the black plate with the wires passing through it. It is on the left side of the evaporator core. I can't remember the number of screws holding the evaporator, but 2 are pictured in your first pic. If they are totally rusted, you might try a vice grip, a needle nose vice grip, or a dremel tool and drill them out.
The 'case' is the housing under the hood. It remains attached to the firewall. The evaporator comes out under the dash.
Good luck. You are on the right track here. Almost this whole job is done under the dash. If you're careful, you won't dump the AC charge and the whole system will stil be operational. You may want to consider changing the blower motor while you're in there. Will save you another trip. Although if you have to go in again, it will be quicker.
BTW, the tech article is from the Ford service manual.
Old 12-05-2005, 10:50 AM
classic79's Avatar
classic79
classic79 is offline
You are almost there. The plenum is the thing that is an air duct. Once you get that black piece out of the way, I think you can unhook some of the wires there too. you will see alot more. the evaportor is what you are looking at. make sure the heater hoses are off the core under the hood, pull that evap out and the heater core is held in place by some metal brackets on the edges. unbolt them the top ones are hard to reach. Once thats out the core will come out, I had to push from the outside to get it loose.
Old 12-07-2005, 03:16 AM
460's Avatar
460
460 is offline
Ok, finally got it done. Thanks for the tips.
Old 12-07-2005, 08:47 AM
76supercab2
Way to go.
Old 12-08-2005, 05:11 AM
460's Avatar
460
460 is offline
I forgot to add this earlier, but the plenum needs removed to allow the A/C hoses enough room to move so the coil can be pulled out of the way. I just moved it down and to the side enough to allow clearance for the lines to slide out.
