I have '92 Ranger, V6 auto 4x4. The dash and tail lights stopped working. Checked fuse and it was OK. Got to playing with headlight switch and dash lights would flicker so figured that was the problem. Put new switch in, and have same problem. Any one have an idea what the problem could be? Thanks.
I found the problem!
It is the switch, and new one from Napa is defective. I can get dash and tail lights to come on with switch betwween the parklight on and headlight on positions. When I pull the switch to park only or headlights on, the dash and tail lights go out. Thank you natebaker for your suggestion. Rod
