Heated mirrors
Old Oct 15, 2013 | 07:26 AM
ahmincha's Avatar
ahmincha
Heated mirrors
Hello everyone Thanks in advance for all replies.
I just bought a 04 f350 SRW 4wd My ? is it only has a heated mirror on drivers side is this oem or did it get replaced through the years
Old Oct 15, 2013 | 07:46 AM
rollerstud98's Avatar
rollerstud98
Factory, passenger side might just be worn out.
Old Oct 15, 2013 | 07:53 AM
ahmincha's Avatar
ahmincha
Thanks for reply. There is no heated mirror symbol on mirror
Old Oct 15, 2013 | 08:01 AM
rollerstud98
Do both your mirrors have the signal lights on them? Can you take a picture of the mirrors. What trim level is the truck?
Old Oct 15, 2013 | 08:28 AM
Misky6.0's Avatar
Misky6.0
I will check tonight when I leave, but I am pretty sure ONLY the driver's side has the symbol - and I don't believe I've seen it "light up" when on either.
Old Oct 15, 2013 | 08:30 AM
rollerstud98
No the defrost doesn't light up on the mirror. I can't remember now whether both mirrors had the symbol or not. Also on the 6.0 trucks the mirror defrost is on automatically, no switch for it. Are you going by just the little symbol in the mirror or experience from frost in the morning with only having the one mirror defrost?
Old Oct 15, 2013 | 12:26 PM
lupuseven's Avatar
lupuseven
my early 04 lariat has that symbol on both. I bought it used though
Old Oct 15, 2013 | 02:19 PM
Champer11's Avatar
Champer11
So the mirrors run heated all the time? I always wondered if I could switch it off. They are usually hot to the touch (both).
Old Oct 15, 2013 | 02:41 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
On the Trucks, the heated mirrors are on all the time, Key On of course.
https://www.ford-trucks.com/forums/9...or-switch.html
For those that are interested.
Old Oct 15, 2013 | 03:20 PM
04badford's Avatar
04badford
My late built 04 has heated mirrors on both sides, maybe its a after market mirror, I thought when you turn the defrost or heat on that's when the mirror starts to work, Hmm see I learn something new every day here
Old Oct 15, 2013 | 04:59 PM
ahmincha's Avatar
ahmincha
Its a xlt fx4 directionals in both mirrors
Old Oct 15, 2013 | 05:26 PM
rollerstud98
Did you have a frosty morning and only one mirror defrosted? If so then you have something wrong in the passenger side mirror. Not sure how easy or even if you can replace the element without replacing the glass. Could just be one of the wires corroded through or something too though.
Old Oct 15, 2013 | 05:39 PM
ahmincha's Avatar
ahmincha
Yeah driver side defrosted passenger side did not. I just wanted to know if they both have the symbol before I take it apart before I buy a new mirror
Old Oct 15, 2013 | 05:45 PM
rollerstud98
sounds like maybe somebody broke the mirror and just replaced it with a cheaper no defrost glass maybe.
Old Oct 15, 2013 | 07:24 PM
Yahiko's Avatar
Yahiko
Take a flashlight and peek in around the mirror and see if you can find the little wires.
They are at the lower edge of the large mirror.
Here is a set of photos I did on how to take the mirror out.
See that red marking that is what you need to work loose with a flat blade screwdriver
You can see the 2 heater wires in this photo
If you need help I can find the post I did on removing the mirror for you.
One thing you want to do is to pop the motor drive pins out of the back
of the mirror and not pull then out of the rubber of the motors. They are a
very big PITA to get back in the robber.
Sean
NOTE : Here is the post I did on the removal of the mirror
https://www.ford-trucks.com/forums/1...or-covers.html
This one is just some more reading about the mirrors.
https://www.ford-trucks.com/forums/1...ror-apart.html
