sloppy steering
Sloppy Steering - Fixes?
I have not found an answer but I guess I can say I am not comfortable with what I have so I have a few questions:
1. I have read the replacement procedure for king pins in the shop manual and am a little afraid of the reaming process. I also noticed that several groups sell over-sized kingpins in addition to the regular ones. Which do I need and where do I measure them? Also I noticed that NPD (and possibly more) sell a king pin kit for $52.25 and a "Special low friction needle bearing" kit for $346.95. Is the expensive kit worth it?
2. What is the preferred method of redoing the steering box. Several places sell all the parts and rock auto sells the whole part. What have others done?
Sincerely,
John
Sincerely,
John
You need to spend some quality time under the truck first. Your problem may not be the kingpins or the steering box, could be tie rod ends, drag link, etc.
1 -- I'd jack up each front wheel and see if the kingpins are the problem first thing. O/S kingpins are for when the pin fit in the axle is loose. To use them, you have to take the whole axle out, take it to a shop and have the axle bosses bored out to fit.
The needle bearing kits reduce effort a noticeable amount, some people swear by them, but there are some potential issues with them. Bushings have far greater wear area, and provide some damping to jolts from the road. To fit the bearings in, the pins have to be smaller diameter. Not a fan, if you can't tell.
2 -- Again, I'd take the box off, open it up and inspect it. It may need all new parts, or it may need just an easy one like the sector roller. If the worm is shot, that's a different game. Investigate first.
I was absolutely shocked when I was putting in my 9" last year. Once the old axle was off, I could swing the springs almost 4" to either side at the axle mounting surface with light finger pressure. The bushings were totally shot, the pins worn 25% off their diameter. If you have that situation on the front, no matter how tight the steering system is, it's going to go wherever it feels like going.
I crawled under the truck this evening and had my son turn the wheel back and forth while I looked. He could turn the wheel about 20 deg before the pitman arm started to move. I assume this isn't "normal" so I think that is my first task. There is also some play when I jiggle the top of the tire in and out. I assume there should be no play there.
John
John
John
John
Accepted play in the king pins is somewhere around 3/32" and measured at the brake backing plate. (Verify this figure) Don't confuse wheel bearing play with king pin wear.
My SWAG is you are going to find wear in all front end parts. A little bit in this part and a little bit in that part and you soon have a sloppy driving vehicle..
Good luck with it and keep us posted as to what you find.
Originally Posted by ALBUQ F-632488
90 wt gear oil -- it's stamped on the fill plug
I can not move the pitman arm in and out. Really nothing seems loose except the play in the steering wheel.
