New Upgraded Sun Visor Question
Old Oct 13, 2013 | 02:36 PM
Chips2000's Avatar
Chips2000
Hi,
Purchased a like new set of upgraded lighted double visors that came from a later year PSD. All I had to do was drill one hole in the ceiling in each side to make it work. Once I had the old ones off, I fished around with my finger in the mounting hole hoping to find a cable to plug the light plug into, but could not find one. I know that many of the wiring harnesses have all the connectors in them, but are just not used in lower models for a given feature that does not come with that option.
Is there a plug hidden maybe down the piller? No big deal if there isn't, I am just happy to have the double visors.
Chips2000
Old Oct 13, 2013 | 04:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is a plug on the passenger side, near the floor board by the door. Pull back the plastic trim piece that is kind of triangular. It is a rectangular plug attached to the wall. This is the plug for factory roof marker lights.
To be really clean, you could try to find the factory harness to go from there to the roof.
Old Oct 13, 2013 | 06:38 PM
Chips2000's Avatar
Chips2000
OK, I will do some digging around. I probably could run a wire up there. On the drivers side, I suppose I could tap off the piller gauge wiring. No big deal, I just like everything to work and my wife might appreciate her mirror being lit.
Thanks,
Chips2000
Old Oct 15, 2013 | 03:31 AM
Supercab's Avatar
Supercab
Wink
Originally Posted by Chips2000
Hi,
Chips2000
I'm guessing that your new visors came from a Lariat or King Ranch truck??
What exactly do you mean by "Double visors"
Old Oct 15, 2013 | 12:35 PM
Chips2000's Avatar
Chips2000
Yes, I am thinking that is where they came from. "Double" meaning that there are two visors per side so that you can swing one to the side window and one stays in the windshield.
Chips2000
Old Oct 16, 2013 | 06:58 AM
ztodd377's Avatar
ztodd377
Sounds nice. Where'd you order them from?
Old Oct 16, 2013 | 11:17 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
IRC those have constant keyed power so what does the cab marker light connector have to do with running power to the visors? You need to run a keyed hot wire up the pillar from either side and to both visors. That way they will work anytime the key is on and not drain the batteries if it gets left on.
Old Oct 16, 2013 | 12:51 PM
Chips2000's Avatar
Chips2000
Yes, I am very happy with them. I won them on e-Bay.
At first, it did not look like they would fit my early '99 and I almost put them back up for auction, but after thinking about it a bit and finding that the base screws lined up with my trucks, I then decided it was worth the risk to grind away some material at the other end of the visors mount and drill a hole near the edge of the roof. Then it worked perfectly and look like the truck came with them.
Chips2000
Old Oct 16, 2013 | 12:57 PM
Chips2000's Avatar
Chips2000
Running a wire as you described is what I need to do, but my wife said she never uses the lighted mirrors in her Navigator, so it may not be worth it. I just like to have everything working, so I might still do it once I run out of other more important improvements for the truck.
Chips2000
Old Oct 16, 2013 | 01:37 PM
truckeemtnfords
I know that feeling, not high on the priority list.
Old Oct 16, 2013 | 09:36 PM
StrokedRanchero's Avatar
StrokedRanchero
Nice upgrade, I thought of doing the same to my e99 at one time but changed my mind. Are they gray by chance? What condition are your old ones in(mainly the drivers)? I'd be interested in buying them, if you don't want them.
Old Oct 16, 2013 | 11:20 PM
Chips2000's Avatar
Chips2000
Sorry, they were pretty badly deteriorated from the sun. This truck has been in the Southwest desert all it's life. Also, they are tan.
There may be a number of reasonably priced stock singles for both sides of your truck on eBay (where I got mine). I had been watching eBay for about 6 months before the tan doubles popped up as a Buy it Now. I don't remember any grey doubles, but I was not paying attention for that color.
The doubles are really worth it if you don't need them right away.
Chips2000
Old Oct 17, 2013 | 06:20 AM
StrokedRanchero
Chips2000
Thanks, I've been checking e bay every now & then. I like the double ones too. I would like it even more if they would extend more when used to block the sun from the side, as I have the seat all the way back, & it don't quite block it.
toothser
Apr 15, 2017 08:29 PM
jimbbski
2009 - 2014 F150
Apr 2, 2017 11:50 AM
microbc
Feb 3, 2017 04:15 AM
ithaca1230
Oct 28, 2013 02:59 PM
supercab78
Oct 15, 2003 10:30 AM
