Backup light switch
Old Oct 12, 2013 | 08:23 PM
F100Mann's Avatar
F100Mann
Backup light switch
I have a 1980 F100, 6cylinder 300CID, 3 speed manual on the tree and my tranny is the Ford 3.03. With that said, can anyone tell or dhow me where in the heck the backup light switch is or should be. I can't find jack on the transmission housing except for the speedo gear on the drivers side and the gear box filler plug on the passenger side.
Thanks in advance!
Old Oct 12, 2013 | 08:59 PM
Franklin2's Avatar
Franklin2
I have never messed with a column shift in a Ford. But I would take a look around the steering column. And you did look at the area where the levers come out of the tranny?
Old Oct 12, 2013 | 09:06 PM
Franklin2's Avatar
Franklin2
I just looked at autozone's site, and they say it might be on the column underneath the brake booster under the hood.
Old Oct 12, 2013 | 09:34 PM
F100Mann's Avatar
F100Mann
Thanks. I have looked high and low. I find nothing that resembles a switch near, on or about the shifter mechanism. I will take a look around the booster.
Thanks!
Old Oct 12, 2013 | 11:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff
It is (or was) on the column, where the rods hook up. They are very prone to popping out of place, and/or getting unplugged.
Old Oct 12, 2013 | 11:11 PM
F100Mann's Avatar
F100Mann
Are you saying it is inside of the cab on the steering column underneath the trim that covers the ignition rod? Please advise, thanks!
Old Oct 12, 2013 | 11:15 PM
Rogue_Wulff
No, under the hood, below brake booster (if equipped) and master cyl.
Old Oct 12, 2013 | 11:30 PM
F100Mann's Avatar
F100Mann
Humm? Ok. I'm going to take a picture of that area so you can see what I do (or don't) and post it.
Old Oct 12, 2013 | 11:52 PM
F100Mann's Avatar
F100Mann
Another failed attempt to attach a picture, sorry forum friends
Old Oct 13, 2013 | 12:19 AM
Rogue_Wulff
I don't see any pic....
The switch *should* be under the hood, below the master cyl. On the column, where it's thicker, there are two levers with rods going to the trans. There should be a bracket holding a "push button" type switch over the top of the lever closer to the firewall. That's the reverse light switch on a "3 on the tree" truck.
Old Oct 13, 2013 | 12:48 AM
F100Mann's Avatar
F100Mann
deleted picture I attempted to post
Last edited by F100Mann; Oct 13, 2013 at 11:16 AM. Reason: users are unable to see the picture I tried to paste
Old Oct 13, 2013 | 12:58 AM
F100Mann's Avatar
F100Mann
| Repair Guides | Instruments And Switches | Neutral Safety And Back-up Light Switch | AutoZone.com
This is what Autozone shows.
Old Oct 13, 2013 | 08:52 AM
truckertrav's Avatar
truckertrav
Here is a picture of where it should be..The boxed in pic...steering column..
The vans and pickups with 3sp on the tree had same setup for reverse lights.
Hope it helps..Trav
Old Oct 13, 2013 | 09:13 AM
ctubutis's Avatar
ctubutis
F100Mann... You can't post pictures from your AOL mailbox and expect them to show up to others here, nobody else has access to your mail....
Old Oct 13, 2013 | 09:16 AM
F100Mann's Avatar
F100Mann
Thanks friend as this is the best pic I've seen regarding this mystery. But where the column exits the firewall, I have nothing that resembles the assembly (15517) holding the switch and I don't find the harness (15525) laying around nearby. Without both there is no 15520-C switch. Is it possible, that a mechanic may have left it off while deinstalling the column? I ask as my column was removed a couple of months ago when my shift column lever failed.
