Question about stock heads
Old Oct 11, 2013 | 04:07 PM
Yahiko's Avatar
Yahiko
How long are the runners from the opening to the valve on
the stock head?
The reason for the question is when I get around to pulling the
intake and cleaning it I was thinking I would clean the runners
to the vales or any soot. I need to know if I can reach in and
get most loose and then suck it up with a vacuum.
Sean
Old Oct 11, 2013 | 09:29 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I have done what your thinking and I believe it worked ok. I used a plumbers brush from the hardware store. It bends a little and I never lost it in there . I kept the shop Vac (with a piece of 3/8 hose taped to the nozzle) running the whole time and made a couple more laps with the vac around all the ports after finishing with the brush. The hose went in farther than the brush. Maybe 6-8 inches on the hose. I would have liked to get it cleaner but dang, I wasn't going to pull the heads to do it because the pistons would have needed cleaning and then......where does the madness stop?
Old Oct 11, 2013 | 10:26 PM
Yahiko's Avatar
Yahiko
At the front license plate of the car behind your truck.
I do know the feeling. How far is too far.
How much crud did you find when you did that?
Sean
Old Oct 12, 2013 | 07:34 AM
Rusty Axlerod
It was pretty gunked up. Maybe 1/16in or more on some ports. The ports toward the front were worse for some reason.
Old Oct 12, 2013 | 09:18 AM
Rusty Axlerod
Kinda gooey when you start trying to deal with it. Look closely, it's thicker than you might think at first glance. I'm not sure why it got like that. I WANT to blame the EGR but from what I read from Bismic and others it likely begins with incomplete combustion making another trip back through the intake via the EGR system.
Old Oct 12, 2013 | 09:44 AM
npccpartsman's Avatar
npccpartsman
The back 4 ports on mine were pretty gunked up and I didn't have an EGR. I did, however, have a VERY active CCV--LOL.
Old Oct 12, 2013 | 12:06 PM
MisterCMK's Avatar
MisterCMK
Scope creep is a bugger...
These are the humble words of MisterCMK sent on the go...
W7PSK
6.7L Power Stroke Diesel
31
Jan 16, 2020 12:46 PM
ALBUQ F-1
21
Jan 25, 2012 09:16 PM
ware8083
1997 - 2003 F150
Jan 12, 2010 08:29 PM
Dylansdad
Sep 2, 2007 08:31 PM
Crazyromi
1978 - 1996 Big Bronco
Nov 8, 2003 03:17 PM
