clunking when first starting to move
Old Oct 10, 2013 | 06:57 PM
bryan5686's Avatar
bryan5686
my truck,a 95 f150,started clunking when i first start to drive,mostly when giving about half gas or so. its a 5 speed trans. ive looked it over a few times and dont see anything loose or any dents in the floor but something hits the bottom of the cab when starting off. anyone had this problem before?
Old Oct 10, 2013 | 08:02 PM
Volvo92906's Avatar
Volvo92906
Check your transmission... Haha.. Mine did that too. Found out I had a broken bell housing. Doubtful thats your problem though..
Youre sure its hitting the bottom of the cab? Any particular spot? Driver side or passenger side?
Old Oct 10, 2013 | 09:14 PM
abitcranky's Avatar
abitcranky
a quick thought....from experience...check the bolts on your drive shaft...front ones to the transmission and the 4 bolts to the rear end. I pulled my transmission a few months ago and lo and behold, the 4 bolts to the rear end were only hand tight. Lucky I decided to do the work before the drive shaft dropped. Also, sounded just like the clunks you described.
Old Oct 11, 2013 | 01:37 AM
Thor'sHammer's Avatar
Thor'sHammer
radius arm bushings, engine mount, cab mount, could be anything really.
Old Oct 11, 2013 | 07:28 PM
bryan5686's Avatar
bryan5686
i went and looked more after work and found a bad exhaust hanger and a dent above the muffler where it had been hitting. thanks for all the help guys
brf2
May 6, 2022 07:32 PM
starwriter
Oct 31, 2011 11:28 AM
bucks77ford
Oct 3, 2007 07:32 PM
JWest
16
Jul 13, 2007 08:58 PM
graymule
Mar 23, 2004 07:04 PM
